TJ2
TJ Expert
Soon as she starts to strip, you wouldn't believe how fast it goes.How fast can you drink a beer?
This puppy was an animal but pricey. Had it on my CJ:
How do you keep that engine sooooo clean, I am a little OCD and wish mine looked like yoursHere is my current set up which uses a Viair 400 series compressor:
https://wranglertjforum.com/threads/how-to-simple-onboard-air-for-your-tj-lj-viair-400h.10235/
I ran a Viair 380c on the shelf under the brake vac canister for a few years worked fine. I upped the ante a bit and installed a pair Viair 485c's w/ an aluminum 3 Gal Tank. I can air up my 35's in 4 minutes from 12 to 25 psi. I could not get myself to breakdown and get the dual ARB compressor for what they wanted.
Sounds like a nice set up. Curious where you fit the tank? Can you send pics of your installation?
Hello,
I would like to ask some questions about air compressors. My main goal is to fill up my tires after my off road rides.
How can I calculate how long do my tires need to be inflated?
Some examples that I found:
ARB High Output 12V - 3.08 CFM @ 0 PSI - 2.34 CFM @ 29 PSI
T-MAX AIR COMPRESSOR - 5.6 CFM
VIAIR 88P - 1.47 CFM @ 0 PSI - 1.25 CFM @ 30 PSI
VIAIR 400P - 2.30 CFM @ 0 PSI - 1.86 CFM @ 30 PSI
Does that mean that the TMAX is faster than the ARB air compressor? or is there anything else that I have to be aware of?
https://www.tirerack.com/accessories/intercomp-4-deluxe-air-pressure-gauge
10.6 CFM at what psi? A CFM rating alone is meaningless. So is a CFM rating at 0 psi.
The Tozalazz guys state this on their website: "11.65CFM, 330L/Min at 0 PSI, 7 CFM at 30 psi."
