That's what I was wondering how does your harness interact with all the gauges?
Not at all… more on that later, think I’m “mostly” there. Basically, rob wires that I am cutting out of engine harness that go to cluster and use for what I need them.
Hoping this may help someone out, if you are in the position where you have a 2006 4.0 6 speed Wrangler, this will hopefully help if you want to cut out all your PCM and engine connectors... I will be making notes for my plans for everything.
@Apparition is planning to do basically the same thing I think so this might help him out.
No six speed though, mine was a 42RLE so it'll be different but I do plan on eliminating everything I can.
O
Should just be the addition of C4 (primarily).
I just scrolled up and looked again at what you posted, didn't look like that earlier. Nice job that will come in handy.
It's why I tagged you for that post... Thought you might be able to use some of it..
I had seen it earlier but the formatting was all messed up so I couldn't follow it.
Unless you change out your dash the PCM will be needed. I suggest you get rid of the PCM.
Great Jeep weekend…. Or maybe nothing got done.
However engine is within hour or two of being ready to go in, hoping whole driveline minus some accessories will be in this week. Probably need to get back to taking some photos.
