Recently installed a 4-inch lift Metalcloak adjustable arms, track bars. 4 Inch Currie Springs. Adams driveshaft (used was on this exact axle but 3.25-inch lift instead of 4-inch), rough country SYE (really good price on the sye could not pass it up). 35 Inch Tires
I took it to a local Jeep 4x4 shop to have the alignment done after I installed the lift. They tried different pinion angles within the range up and down a few degrees and it's still getting vibrations. They installed a 1-inch skid plate drop and said it went away but had just a slight vibration at 60 also said it could have been the new tires. They took the skid drop off when I went to get the jeep (it was for a YJ all the holes did not line up) if that matters lol.
Prior to putting the lift on I had the drive shaft and sye on for a short period of time with my 2-inch lift and 31's.
I've ordered Browndog rubber 1-inch motor mounts to try and get the pinion down. Coming in next week. I also went and got washers/longer bolts to make a temp skid drop kit.
I really don't want to lose the clearance and drop the skid plate.
My question is should there be a vibration with a sye installed and pinion angle set correct? Has anyone else had this problem?
