3” lift to 4” lift
A small 1.25” body lift is the best “bang for your buck” mod according to the guru @mrblaine. If you are eventually moving to 35’s then you’ll want a 1.25” body lift. Might as well go ahead and do a 1” motor mount lift at the same time so you don’t have to move the fan shroud.
You shouldn’t need longer front brake lines with a 3” + 1.25” lift but you should cycle your suspension to see where they are. At 4”+ 1.25” you usually do need the longer Dorman front brake lines.
For the body lift go with BMB 1.25” acetal pucks. Good luck!
Very helpful!
