your already there, outboard those things!!!
It’s in my playbook!
I know which one I like better... What say you?
I got the rear frame tuck done. I’m just painting it now. Now I’m wondering, should I move the upper perches next? Or should I do the raised body mounts? Either way I’m not putting the gas tank back in until I’ve done all this. The last thing I’ll do is outboard. Some pics from the process. Grinding gets old!
Did you end up adding a fish plate?
Wow, those look so different.. do you have to deflate to get out of the garage?![]()
Man as nice as your other Jeep is I can't wait to see this finished
Pre or post flop?![]()
It’s art. You know a thing or two about that.
Great work as always Jeremy! I know we discussed via text, but I really think now would be a great time for a stronger GTS. It's going to get more use with the tucked frame.
That said, I haven't kept up with the market, the problem is there may not be a good GTS available at the moment!
The fuel pump is a newer Delphi so shouldn't be any worries there I would think.
