I've got a few Warn cables that have the size listed on them as X square mm. Fortunately the 9.5 isn't messing with that BS, yet.
If you need a hydraulic crimper I have one you can use.
This should work for a battery tie down. Thanks for the good ideas.
Don’t forget to move the pcm up and route the pdc harness under the battery box.
The only issue in this design is that it doesn't allow much adjustment if it needs to strap down more than the tolerance you built in. However, you can just wedge something(s) in that top piece if you need to.
Halfway done!
This is much more meaningful after reviewing your thread when you were doing HiLines.![]()
That is interesting...There isn't a standard gage size for 25mm² wire...Smaller that 3 ga, but bigger than 4 ga
Also interesting...Another "standard" table that has different mm² sizes for AWG
I removed the cats to replace them and this cut was there right where they mate to the manifold. Can I just weld it up and grind it smooth?
WTH is standard metric? 25mm squared SAE?
I hate the metric system. I’ve got a friend who has dedicated several hours a year to make fun of it. He’s not even from America. He’s from Ukraine.
We were looking at skis a couple years ago and you wonder how long they are and it says something like 297mm. I’m like, WTH is that? Have to go convert every time.
