I'll never understand this attitude. How much beach do people need to be able to go walking on? So you don't like motorized recreation then go to areas where it isn't allowed.
It's the same with closing the woods down.
Also they close down the beach because of our horrible pollution. But have no problem covering every square inch of area around the beach in housing developments.
Also in Tahoe where they close down 4WD trails because of oil getting into the forest but when it rains I can see oil running off the pavement into the ditch.
Its not about the issue...Its about control. You're doing something "they" don't like, and "they" want you to stop.Also they close down the beach because of our horrible pollution. But have no problem covering every square inch of area around the beach in housing developments.
Well Alex,
When your thread gets this far off topic it’s time to upgrade.
What is the ideal wheelbase for 37’s?
"If you're gonna play the game, boy100" easy peasy frame stretch. Unless he's doing the coilovers at the same time then just blank corners....
Transmission bell housing bolts.I found my second least favorite bolt on the TJ. Bonus points if you guess it. View attachment 279889
Too easy. What @Daryl said.I found my second least favorite bolt on the TJ. Bonus points if you guess it. View attachment 279889
I guess all the hard ones are just burned into people's memories.Too easy. What @Daryl said.
Only if you've ever had to pull your tranny.. Or other hard to get to parts/bolts.
Top bolts on the tranny bellhousing, but I only surmised from the fact they are really weird and I knew you were thinking about doing the clutch. I don’t think mine are the same. I believe mine are an E-5.I found my second least favorite bolt on the TJ. Bonus points if you guess it. View attachment 279889
