Several months ago I moved my factory Rubicon locker pumps under the hood. After the install pumps worked as intended by running a few seconds until enough pressure had been built up then shut off. Recently I noticed that both pumps will run for a few seconds then shut off as normal but will run again about every 5-10 seconds for a very short period of time. In troubleshooting I removed the outlet hose from the pump and stopped it with my finger. The pumps rapidly start/stop now every second or two. I thought I should be able to make a good enough seal to stop the pump with my finger. Both pumps are doing the same thing. Bottom line is I am trying to find an air leak and cant get through what I would think is the first step, plug the air outlet with a finger and ensure the pump shuts off as it should.
