Left soundbar speaker doesn't have power
CodyMan
Sacramento
I installed new speakers and the right one works fine, but the left one doesn't have any power to the wires.
When I purchased my '01 Sport my Jeep had the same problem with one of the sound bar speakers not working. Did some troubleshooting with the speaker wiring and discovered one of the speaker wires in the factory radio harness connector had pulled free from the harness connector in the back of the radio. Reinserted the loose wire into the harness connector which solved the problem.
Do some continuity tests with a VOM (multi meter) and you will find the problem.
Thank you it was the harness, one of the wires was not even stripped and it just pulled right out of the connector.
Reactions: CharlesHS
