For others to note Trailready will make them however you want them.17 X 8 Raceline beadlocks. Most of the 17" options will require that you buy JK wheels and use 5 X 4.5 to 5X5 adapters. You can also run larger brakes which is nice.
The next Jeep over is Walker Evans.
I want to be a suicideking without the side effects. I love your jeep.17 X 8 Raceline beadlocks. Most of the 17" options will require that you buy JK wheels and use 5 X 4.5 to 5X5 adapters. You can also run larger brakes which is nice.
I've never seen anything on Racelines site about custom, so I was unaware.Pretty sure Raceline will too as will many Beadlock mfg's. I know Allied will, called them and they would do any combo.
Probably going to need custom wheels then. I'm not aware of ANY 17" wheels on 5X4.5 that have decent backspacing. Not sure if you want beadlocks or not, but should be able to find one of the wheel companies that will make you some.I’m pretty much stuck with the 4.5 bolt pattern I have a hub conversion and don’t wanna run spacers or buy a whole other kit.
That’s what I was afraid of. Tires for 15 inch wheels don’t have a ton of choices in sizes. I’m not looking for beadlocks since I don’t really wheel it anymore.
My Fuel wheels have the correct bolt pattern and the backspace works fine with my 315/70 R17 tires.Probably going to need custom wheels then. I'm not aware of ANY 17" wheels on 5X4.5 that have decent backspacing. Not sure if you want beadlocks or not, but should be able to find one of the wheel companies that will make you some.
Thanks I will look into those!My Fuel wheels have the correct bolt pattern and the backspace works fine with my 315/70 R17 tires.
