I used this vendor of ebay https://www.ebay.com/itm/2727613655...d=link&campid=5337789113&toolid=20001&mkevt=1If you wouldn't mind, which rebuild kit did you use? Thanks!
thanks
Thanks for the suggestion, I actually haven’t actually verified power at the switch yet. Just took a shot in the dark with new switch. I’ll have to actually start testing wires now. Thanks!If you have power at the back up switch when in reverse, then you at least know the problem is downstream of that. which is just wire and sockets and bulbs.
Did the vaccine shot effect you any?Went out in public today because "follow the science" Joe said I could (without wearing a mask). I got some really strange looks at Walmart when I went inside though.
I had the Pfizer and had a 2 day sore shoulder each time.Did the vaccine shot effect you any?
Almost finished turned into 5 more hours. But finally onto the front.
First one didn't. About 16 hours after the 2nd shot I developed some pretty bad "Flu like" symptoms. Nausea, headaches, body aches and 100.4 fever. All that lasted another 16 hours before it went away completely. This was the Moderna vaccine. I had Covid and was really sick for 3 weeks last year so I don't know if that made any difference. The wife got the Pfizer and was just tired. Sore shoulder is a given for both.Did the vaccine shot effect you any?
Looks good. What brand? EAG? Post pics when you're done.I agree, not high quality stuff, but I like them and they will do for a while (I hope)![]()
What brand are theuI agree, not high quality stuff, but I like them and they will do for a while (I hope)![]()
Looks great sir. And thank you for your service! My son is active duty Navy. Hooyah!With this weekend on it's way I decided to show my pride in my 20 years of service as a U.S.N. Seabee by putting decals on the Old Boy! I topped it off with a Bullet Flag Type cowl decal.. I like it and I prefer my Patriot Blue Jeep over an Old Navy Gray any day!
How hard was it to replace the cigarette lighter? I would do this in mine, can never have too many USB ports! Where di you get the USB port?Actually this week. Replaced the entire sound system with a budget upgrade. Head unit (Pioneer MVH-S322BT) to replace the former Sony with only CD and radio- welcome back to 2005. On the upside the PO didn’t cut the harness so the wiring was much easier. Replaced the speakers with Polks- 4x6 in front, 6 1/2’s in back- and put some budget dynamat and poly fill in all the cavities while I had a chance. Added a sound ordnance self powered sub which fit perfect in my console. Unfortunately I think i might need to get an exchange on the subwoofer since it’s not delivering much added low end. Love the new sound and ability to use the app, Spotify and other phone features much easier.
Also replaced the cigarette lighter with a double usb charger using the existing wiring.
Thanks to the forum for the great write ups on these products and install how-to’s, tips/tricks and advice.
Thanks for your comments - and it was my honor to serve - God Bless You and Your SON !Looks great sir. And thank you for your service! My son is active duty Navy. Hooyah!
WOW - this is soo great! But NOW after I went to the trouble to add a Volt Meter windshield post POD (see attached pic)... Well it seems that I am always a DAY LATE and at least a DOLLAR SHORT ! However, it is a great install - and I may still add the USB charger port in lieu of the Voltmeter combo. Thanks.‘Pretty easy. I mostly followed this thread- https://wranglertjforum.com/threads/installing-a-3-0-dual-usb-plug-voltmeter.19055/
Used the same USB charger port he links to in his post from Amazon. A few things I did different from the original poster:
- Removed the cig lighter plug and installed the new plug there rather than in a separate hole. Lighter socket doesn’t come out easy. I just crushed the metal part with pliers and then it came right out.
- Used a round file to widen the existing lighter hole. The usb charger is slightly larger. Took me about 5 min. You could dremel it faster I’m sure.
- I used the existing lighter power which is only on when the Jeep is on or in accessory power. The original poster wanted it on all the time like the power port, but I didn’t care. Wire black/white stripe from Jeep to black from usb and blue/white to red.
Took maybe 15 min
