So I have a plan for my LJ and I want to put it out there for all to poke holes in before I start pulling trigger on parts.
Jeeps Purpose: I have no plans on ever selling this jeep, as far as I’m concerned, I may be buried in it. I will do whatever is needed whenever its needed, up to and including repowering, rebuilding, reframing, ect. So budget is not a problem, however I want availability of parts 20+ years from now, and I want to keep needless expenditure low.
The goal is 33in tires and about 3.25- 3.75 in of over all lift, the jeep will be an 80/20 on-road/off-road, and needs to remain drivable for extensive freeway journeys (500+ miles). It will see old fire roads and mild to moderate trail use and won’t be hitting the hard stuff (at least not on purpose, I’ve made wrong turns before and probably will again).
The main outcomes are for reliability, repairability (long term), and make the sacrifices to drivability as small as possible.
The Plan: (may not be in order)
-Savvy 1.25 BL
-Savvy cable Shifter 241OR
-MORE pillow block lift
-MORE Bomb proof 1in motor mounts Or Maybe just a motor mount lift, thus retaining stock motor mounts which should be easier to find in the future.
-Rough country #1044 front track bar W/ Moog K7252 bushings.
-JKS rear track bar Relocation bracket Or Rough country #1075 Rear track bar W/ Moog K7252 bushings
-Rancho RS5000x shocks (please chime in on what part number yall think will work best here)
-JKS 3in dual rate springs Or OME2996 Rear and either OME 2933 or 2934 front
I do need recommendation on the springs, its an Lj hard top with warn rock crawler front bumper and a Warn 9.5ti. out back is a Genright 31.5 safari tank. And in the middle (I am not a typical Tj owner at 6’8” 380lbs) is about 800lbs between me, my wife and the dogs before cargo.
-Mix between daystar, spacers, and hockey pucks for bump stops
-Brake lines don’t know if I need them yet
-Stock for now other than thick tie rod, (maybe Currie correct lync, Zj conversion, possibly even a Wj brake conversion with crossover in the future.)
-UCF deep cover extra clearance skid ¼” aluminum
-Rough Country quick disconnects front ( I own um, may as well rock um till they drop. Thinking SwayLOC in the future)
-Extended Rear Sway bar links
Go to town, poke holes in my plan, stop me from making mistakes. Good, bad and ugly I want your guy’s opinions.
Mostly stock on bottom( has gas tank, front bumper and winch)
Top is current (265/75, RC2.5 lift(wife tried to buy me a nice present, she didn't know))
-Savvy 1.25 BL
