After some diagnosis at my friends shop Bavarium Autosport‘s it looks like my engine needs to be replaced...
Engine failed compression test and leak down found two cylinders around 80% the others were around 30%. Surprised this thing still ran.
My friend found two injectors intermittently fully open. Looks like over fueling caused the two cylinders to fail. Failed injectors and PCM.
Originally I was planning on saving for a year and replacing the engine with a stroker. Looks like the Jeep can’t wait that long. After a bunch of research and checking pricing online for engine options. I decided to replace the engine with a used engine from a local Jeep wrecker J&W Jeep. The engine has 41k original miles from a 2006 Rubicon. It was $1850 including a set of Exhaust manifolds (Headers Leaking). I felt like this was a good price for an engine that should last me a few years until the stroker.
I have built out a few other vehicles in the past and I have over 20 years in the automotive dealership world. I might be going a bit overboard for some. The Jeep has 170k miles on it, I am planning on replacing quite a few parts while the engine is out. Most of the parts are going to be OEM with a few exceptions that I have not seen the value in spending the extra money on. Any input is welcome as this is my first Jeep.
Below is the parts list going along with the engine replacement.
OEM Parts
Radiator
Water Pump
Serpentine Belt
Idler Pully
Belt Tensioner
Intake/Exhaust Manifold Gasket
Crankshaft Damper
Engine Lower Gasket Package- (Oil Pan, Timing Cover Gasket, Water Pump, Oil Pump Gasket)
Front Main Crankshaft Seal
Engine Mounts
Heater Hoses
T/Stat Gasket
Throttle Body Sensor
Crank Shaft Sensor
Coolant Temp Sensor
Air Temp Sensor
MAP Sensor
Oil Pressure Sensor
Ignition Coil Assy
P/S Pressure and Return Hoses
Coolant
Oil Filter
Aftermarket Parts
Valve Cover Gasket- Fel Pro
Radiator Cap- Stant
T/Stat- Stant
Radiator Hoses- Gates
Fan Clutch- Hayden
PCM- Wranglerfix
Fuel Injectors- Precision Auto Injectors (Rebuilt)
P/S Fluid- Lucas
Spark Plugs- Autolite XP985
OEM Parts
Radiator
Water Pump
Serpentine Belt
Idler Pully
Belt Tensioner
Crankshaft Damper
Engine Mounts
Heater Hoses
T/Stat Gasket
Crank Shaft Sensor
Coolant Temp Sensor
Air Temp Sensor
MAP Sensor
Oil Pressure Sensor
Ignition Coil Assy
Coolant
Oil Filter
Aftermarket Parts
Radiator Cap- Stant
T/Stat- Stant
Fan Clutch- Hayden
PCM- Wranglerfix
P/S Fluid- Lucas
