Or.... Maybe the Mamba MR1X. I've never been too keen on running spacers but as long as I know that I've torqued them correctly, plenty of people do it right? It would be the closest I'll get to Moabs because I refuse to go above a 15" wheel
Thank you! I'd definitely love to get the Currie lift, I think I'm just to the point of piecing it together slowly or doing a hybrid approach.Hey seabass - following this build and great progress so far. If you need any reason to spend more money, the Currie lift paired with the RS9000 Ranchos is great (though I have nothing to compare to). I think you are tracking correctly on getting the things you need though before replacing the Zone lift.
As a side night, I recently upgraded the LJ to BMB front pads with centric rotors and it is unbelievable how much better it performs from stock. If you ever find yourself lacking confidence in the braking department after the recent changes, certainly look there.
If you don't mind me asking - were are you located in NC?
I like these American Racing AR969 wheels.. more expensive but I'm willing to pay more for a name brand wheel. Opinions?
That's it, don't get too close and don't look at it under direct sunlight!Ah - that explains the snow earlier this month you posted about. Yes - after two black vehicles in the past, and countless days of paint correction, I avoid it all cost though it's hard to beat the looks of black (just don't get to close).
Regarding headlights - are you opposed to some cheap knockoff's from Amazon. Not sure if you have upgraded but it is one of the best things I have done for less then $100. Well that and the Alien sun shade. Hard to beat that in the NC summers.
Those do look really good.. you've even got the next set of tires that I want on them too..
Thank you. Wheel choice is very subjective. Everyone has a different opinion of what looks good. It's a good thing we have so many choices.Those do look really good.. you've even got the next set of tires that I want on them too..
Whatever I do go with, I'm about 90% sure it will be silver. I'm really back and forth between 3.. yours, the Qtec Rubicon Xtremes in silver, and the Mamba MR1x in silver. I like the factory look of the latter two. The other 10% is the Method 304 in black.. for some reason I just like them, and they don't make a bare aluminum. The 301 comes silver but it's a 15x7Thank you. Wheel choice is very subjective. Everyone has a different opinion of what looks good. It's a good thing we have so many choices.
I think a silver wheel would look great on your black LJ.
Yes the bolts are easily removable.@DuncLJ are the bolts around the ring removable?
That's a good point! I figured the wheel was all one piece but I like that the bolts are removable.Yes the bolts are easily removable.
The ring is not removable. It is a 1 piece cast wheel.
The bolts would be easy to replace if 1 fell out or was damaged, or if the ring got buggered up with trail rash, it would be easy to remove the bolts and touch up the ring with spray paint. You wouldn't have to do as much masking.![]()
Love the BL. Makes washing the mud off so much easierYou can see the ‘gap’ with a 1.25” BL, more of course at back, but I don’t think it looks bad.
Stock
1.25” Savvy BL
Eventually I will get one, probably not until I get a tummy tuck and all that comes with that though.Love the BL. Makes washing the mud off so much easier
