Upgrading the sound system on your Jeep Wrangler TJ
My factory stereo won’t play cds anymore and I’d like the ability back. Along with maybe Bluetooth. Is there a specific brand of head unit/stereo that is better than others? Any to stay away from? I have always either had a Kenwood or Sony, but there was no real reason.
I also listen to CDs and have a Kenwood. It's solid and has great Bluetooth streaming. Unfortunately Kenwood HUs are hard to find as production slowed down during the pandemic. Crutchfield has a nice looking Alpine that would fit your needs.
https://www.crutchfield.com/p_500CDE175B/Alpine-CDE-175BT.html
There is a great car audio guy in Edison, if you live near there. He may have some Kenwoods in stock if you cannot find what you are looking for.
https://unexpectedcreations.com/
Reactions: TWiG01
I was browsing Crutchfield and there are so many options. I have a sizeable cd collection that I should convert to MP3, but for some reason I still enjoy putting in a cd. Thanks!
The quality, to me, also sounds better. I keep converting my CDs to a USB thumb drives and I still like my CDs more.
Reactions: TWiG01
Thanks, that Alpine unit is nice. I’m in Cape May, so Edison is a bit of a hike. I’ll definitely be tackling the install myself with the kits they have on Crutchfield. I agree, the CDs definitely offer superior sound quality. Thanks!
Reactions: skrelnik
I have the Jensen "Heavy Duty" head unit. Mine is just AM/FM/Geek stick, which is exactly what I needed. They do make other versions with with CD mechanisms and I think maybe Bluetooth as well. They look far better to my eye than most mainstream units, and are environmentally hardened. I installed a JVC AM/FM/Geek stick/CD in the old Mercedes in 2016 because the old AM/FM/CD started acting wonky after 15 years. I instantly found that I virtually never used the CD player but used the Geek stick most of the time instead. So I didn't bother with CD in the Jeep. The JVC has about 50 tiny buttons on it that aren't exactly an ergonomic paradise, the Jensen is much nicer.
Reactions: TWiG01
I almost always (maybe always...) post all of my projects on "what did you do to your TJ" but this thread is much more appropriate. I will mention there as well with a link to this page so everyone there can check it out if they want.
I upgraded my stereo and speakers this weekend. After a lot of reading and researching I gave it a go!
For the stereo or as some call it, the head unit I opted for is the Sony DSX-GS80 - https://www.crutchfield.com/p_158DSXGS80/Sony-DSX-GS80.html . It a little on the pricier side but I'll explain my reasoning in a minute. The unit does not have a CD player but I can't remember the last time I used a CD anyway. I typically stream from my phone library of music or just listen terrestrial radio anyway.
I chose this received because it has a high power built in amp. Most receivers come with a small built in amplifier with something like 15-22 watts RMS which my previous one had. I was at 18 watts RMS but this new unit is 45 watts RMS and 100 watts peak which is more than double what I had. I really didn't want an external amp. I didn't want to have to find a place to mount it and run all the wires for it and so on. I wanted a simple solution and this stereo solved that problem. I have the OEM subwoofer and amp in the center counsel and with this upgraded stereo and the speakers (which I'll get to next) I installed, there really isn't a huge need for anything more....for me anyway! I figured a different receiver would cost roughly $100 and an amp would be minimum $150 plus all the wiring that's necessary for the amp, this was a more economical choice and easier by far!
As for the speakers, I went with the Kicker CSC5 (5.25") in the dash and Kicker CSC65 (6.5") in the sound pods.
5.25" speakers - https://www.crutchfield.com/p_20646CC54/Kicker-46CSC54.html
6.5 " speakers - https://www.crutchfield.com/p_20646CC654/Kicker-46CSC654.html
I had to get the brackets to mount the 5.25" in the dash corners. I didn't have to cut anything to make them fit. from everything I've read, in the 2003-06 you don't have to remove a metal bracket in order for these to fit.
Mounting bracket - http://rover.ebay.com/rover/1/711-5...0001&campid=5337789113&icep_item=202963397928
Speaker baffles (Boom Mat) - https://www.amazon.com/gp/product/B07N4DP5Y7/?tag=wranglerorg-20
As for the rears, it wasn't difficult, but without the right tools, it could be a little more difficult for someone. The sound pods in our later model TJ's as opposed to the earlier model sound bars are not capable of accepting the 6.5" speakers...without modification that is.
I had to cut out wood circles and then I used a router to sand them to size so they could fit in the recessed part of the sound pod where the OEM speakers mount. I had to build that recessed area up to make it level with the rest of the pod to mount the speakers how I wanted them to fit. After the ring was installed into the factory mounting holes for the OEM speakers, I then mounted the new speakers to the wood ring and then the grills are mounted, which do require a new set of holes in the sound pods.
*NOTE* unfortunately I didn't get a picture of the rings I made after I had them mounted in place but below there is a link to something very similar, someone 3D printed theirs. If I ever have to remove my speakers for any reason, I can get a picture then and edit this post.
However, the wood rings are not necessary, I do recommend them. It makes it much easier mounting the speakers where you want them otherwise, you run the risk of them being mounted off center which will be noticeable. They don't sit in the speaker holes well so these wood rings help big time to make sure you mount them centered.
For those of who have a 3D printer or know someone who does (I don't, hence the wood rings) I did find someone who posted what appears to be download files for these rings that you can print. Maybe that will be helpful if you don't have the means to fabricate what I did? I don't know how to tell if this download file is legit so I will post the link and someone that has a 3D printer can verify the validity of the download file and report back.
Here is the link to that page where it shows the 3D printed ring so everyone can have a visual. The download file is on this page as well if you click below the picture that says "Thing Files".
3D mounting rigs for 6.5" speakers in speaker pods - https://www.thingiverse.com/thing:4617429
Now that it's all done, I can say that I am happy with everything. It sounds so much better than what was in there. As a side note, the speaker pods do have poly fil in them to help with the sound quality. I put that in over a year ago and it helps! I am very much into good quality sound and I do like loud music and I also like to "feel the bass" but this set up doesn't allow you "feel" the music like a much more expensive and elaborate system would cost but I am very pleased with it.
Nice Job. Since you are up in Michigan, one update I must recommend is to fill in this blank with the below Dorman heat seaters.
https://www.amazon.com/dp/B002U6IL9O/?tag=wranglerorg-20
Reactions: dschwes
Very nice, I’ve never installed a receiver myself before, but I will be tackling it when I order one. Is the install pretty straightforward?
Reactions: dschwes
Not difficult at all. If you order from Crutchfield they’ll set you up with everything you need including step by step picture instructions and free tech support for any questions or issues you may run into if you’re not quite capable or confident. Their prices are on point with any website or retail store and shipping is only 3 days roughly. The tech support is worth its weight in gold if you’ve never done one and need to talk it through with someone.
Is your current radio OEM or has it been replaced before?
What would you recommend for a subwoofer to go under the rear seat? I do not have the center console subwoofer and the previous owner of my jeep also wired it for a subwoofer to go in back (I'm hoping his wires work). My sound is not the best right now (especially with bass), I have some kicker rear speakers the po installed and these cheap front speakers I bought since mine were blown and they're not the best
Just installed this kit the other day, I'm not good with electrical stuff but I was able to make it work pretty easily. They warm up really well, I had to bend it a little to be able to shove it up into the seat (I definitely could have done it better, I didn't/don't know how to use the hog ring plier things that came with it) but it seems good to me
I have the factory radio still in the dash, so all the wiring should be unmolested. I wish the CD player still worked because I like the factory appearance
I swapped out my factory receiver (AM/FM/CD/Tape) with this Kenwood
https://www.crutchfield.com/p_113KMX704/Kenwood-Excelon-KMM-X704.htm.
While it works well and has good sound and has just about every function one could ask for, it's just annoying to operate. It's almost as if it has too many functions. The buttons are tiny and the display is difficult to read when the top is off (which for me is all the time since my jeep is not my daily driver). It also just looks out of place. I would go back to the factory receiver in a heartbeat if only it supported bluetooth or had an iphone interface or USB connectivity. I did just find this RetroSound unit one and I have to say, it looks pretty cool. Old school design with modern functions - bluetooth, dual USB connectivity, satellite radio connectivity, able to connect to an amp and other aux ports. It's 1.5 DIN so it fits correct and it doesn't look fancy enough for a shitbird to waste his time trying to steal.
If anyone has installed this one, I'd like to get some feedback before I purchase.
https://www.crutchfield.com/p_068NYM4/RetroSound-New-York-M4.html
Reactions: dschwes
That's good then because the factory harness will just plug into the adapter that you'll get with the radio you choose if you go through Crutchfield. You can get the adapter anywhere but they include for free everything you'll need. I didn't remove my factory radio, the PO had it replaced with a garbage radio in my opinion but I think you'll need to remove something behind the factory radio in order to fit an aftermarket one. Its some sort of a bracket I think I read. I didn't pay any attention to it because I knew it wouldn't be in my way since the radio had already been replaced before. I also believe that you WILL have to replace your speakers but don't quote me on that. Others on here can confirm that for you.
Reactions: TWiG01
You ain't kidding, it is an old school design! It looks janky but it has all of todays cool features and you're right, nobody is stealing that if you leave your jeep for a few hours parked somewhere with the top and doors off!
Some head units are too much for some people. These are basic head units with a lot of functions, you can dial in if needed.
I love the head unit you have, great model. What issues are you having?
You can add an amplifier to the factory head unit, and add bluetooth to the amp itself, and retain the stock head unit. Anything can be done. You are in Jersey and can pay Don a visit if you want to go that route.
Honestly this may be the route I end up going. I have aftermarket Polk speakers that will probably sound a lot better with an amp. I didn’t realize you could gain Bluetooth connectivity from an amp
