Track bar bushing causing death wobble
If Dave is replacing the stock bushing of the stock track bar with the k7252, then I'm still confused about what problem is being solved. Even if the entire purpose is to use the larger bolt. But no harm is being done either.
@Dave Kispaugh may chime in. I think it's a bolt upsize
and a way to get the Made In Mexico bushing that doesn't last out of a Rough Country track bar he likes the bend of. . and that's the short route., Sort of a 2 for 1.
I sleeved mine for a 12mm rather than 14mm, because 14mm hardware choices are more limited generally.
I liked it a lot, after having what the OP had , so I did it in my 06 that has a stock bar. For me it was a way to avoid buying a nicer track bar.
Reactions: KCsTJ
