Ok. The bolt was loose and contributed to death wobble. You corrected that by tightening the bolt. And now you also have a garbage bushing that you get to replace in the near future after you complain about the shaking.
I can assure you the old bolt was tight. As you mentioned earlier in the thread to tighten the bolt which I tightened to 55 ft lbs and then even as high as 70 ft lbs. The bolt had no play in the bushing the bushing itself had the movement. Did I have a bad bushing from the factory? Very possible! Could replacing it with the same bushing have fixed my issue? Maybe! But this is what I did and so far it has fixed my issue. If the bushing is so junk and you say no one has ever had an issue of death wobble with the JKS track bar then why would JKS themselves sell a HD poly bushing as an upgrade? Not saying I am right and you are wrong or vise versa but there can be multiple causes and thus multiple solutions. If I end up replacing the bushing due to it being junk I will update this thread so if anyone reads this in the future and has the same issue they won't use my solution.
