Previously I installed a separate wiring harness for the headlights which increased voltage to the headlights (11.3 to 14.1V). This modification increased the amount of light the headlights produced plus reduced the load on the factory headlight wiring and MFS. Today I installed a set of Hella E code headlight housings and H4 60/55 W bulbs.
The Hella H4s produce a good amount of light for $77 and are not near as expensive as LED headlights. I am not fond of the higher wavelengths (5000K and higher) that most headlight manufacturers use.
