It’s a really good thing you ended up going with those engine mounts! Your stock ones were cracking badI haven't updated this in awhile. I seem to like to just put the things I do to it in the "what did you do to your tj today" thread. LOL
Since the last photos the main thing I did was add the winch.
Went on a 4 wheel drive run with a group here in Sac.
Installed some grab bars,
Then made them purple.
Installed a set of JKS quick disconnects I got from a member here.
Went on another 4 wheel drive run with another group here in Sac.This was the first time disconnecting my links. This is where I found out I wanted a lift. LOL
Me and my co pilot.
For that run I wanted to take some chairs and it is always a pain to have the chairs in the back and still be able to open my drawer to get to our lunches and all. So, I made a platform to hold the chairs. I'm going to make it cover the whole back in this summer, but in a pinch this worked.
My radio quit on me again, so I found this cheap radio at Walmart. With 2 year warranty, came to 22 bucks.
I was finding that when the door was fully open, I would grab the door panel toward the top to pull it shut. So I made a parachord lanyard to pull it with.Works great!!
And finally, to get things all caught up. Today I installed my 1.25" Savvy BL and my Brown Dog 1" MML. For the most part I did the BL by myself.I did have to have hubby's help in the MML. That was a pain in the a$$.
Getting ready to start.
My helpers
We found these 2 hiding between the radiator and the grille. Hubby had to fish them out with a magnet.
Left over parts.
I forgot to take a pic of the original height. It was 18". I remembered to take a pic of the after. It just didn't come out that great. A little over 19" now.
Here are some after pics.
View attachment 146383View attachment 146384View attachment 146385View attachment 146386View attachment 146387
I can no longer see the grille guard from the inside.
I'm going to be painting that dirty piece to the left black eventually.
And here are the side by side pics. Before on the left after right. You can see how the grille guard now sits lower then the hood. I will be raising that up a bit eventually. I can't get to the headlight screws that easily with the way it is now.
Ok, all caught up.![]()
Now the purple people eater is getting some beef! Trail worthy for sure! Good times!!!I haven't updated this in awhile. I seem to like to just put the things I do to it in the "what did you do to your tj today" thread. LOL
Me and my co pilot.
My helpers
Left over parts.
Ya. Those stock mounts were shot. Looking good.
Have you done the 2x4 test yet to see if you like the idea of going higher?
It’s a really good thing you ended up going with those engine mounts! Your stock ones were cracking bad![]()
Looking awesome!Got the lift put on today!!First thing we did was went to the car wash so hubby could clean the suspension a little.
We started in the back. Went pretty well but I will have to say, we are not very good at it. The rear is still a little out of adjustment. We didn't buy a bracket for the track bar and put it in the original track bar location. To do that, we had to put the adjustable part in first, then put the other end in. Here is where I ran into my first issue. I tried to tell hubby we needed to put it on the ground and then figure out how much adjustment we needed. Well, him being him, didn't want to do it that way. He measured it up in the air. We had do lower the exhaust to be able to turn the track bar to adjust it out a bit. Once we did get it back on the ground we measured and it is just under a quarter of an inch off. I'm calling it good enough for now and I may buy a bracket later down the road so it is easier to adjust.
Then we moved to the front. Here is where my other issue came along. We were doing good and it was going pretty smoothly. Then I told hubby we had to drill out the hole bigger to attach the trac bar. So he started to do it and didn't have a sharp bit, so he got it just so the bolt would almost go in. He said would be able to get it to thread in and it would be fine. Well, it wasn't. It messed up the threads. It wouldn't tighten up all the way and he ended up having to cut the bolt in half to get it off.
Had to run to the hardware store to get another bolt. Got back and he got the hole drilled out all the way this time and things went well after that.We got the front dialed in really nice. Even on both sides.
Here it is all done.
Some before and after pics.
View attachment 159972View attachment 159973View attachment 159974
With body lift and then with lift too.
The day I got it and now!
So it went pretty well except for hubby not wanting do do as some of the instructions said to do. LOL I'm going to take it on Monday, I hope, to get the alignment. It seems to look ok, and goes down the road fine, but figure from what I read it is best to have it done after a lift.![]()
Looks great!! Did you take measurements of the gain? It looks like a lot more than 2" in the rear.
