My first submission- hopefully someone has had this problem. When driving, I used my turn signal- the arm felt sticky and then gave. The turn signal light on the dashboard is a stick "on" not blinking. After 4 mins or so, the signal warning starts beeping. However, the turn signals still worked. I figured it was my turn signal switch- easy enough replacement.
So now the turn signals dont work at all- but I do still get the dashboard signal light "on" . Any ideas? there is a little plastic lever on the inside of the turn signal switch could it be something with that? or is it the turn signal flasher module?
thanks
Jamie
thanks
Jamie
