Painted the high pinion Dana 30! Rust-Oleum hammered was the paint choice.
What did you do to prep for the painting. I recently bought a Dana 44 that I will eventually install in my TJ replacing the Dana 35. I was thinking of once I have it all stripped down I would take it to a local shop and have it sand blasted. Once it is nice and clean I would paint it. Did you clean/degrease the axle yourself? If so what did you use?
Reactions: Jake kozlowski
I was able to continue on my front axle today, tomorrow I will remove the coil spring to better remove the rust.
I wish my axle would be as beautiful as Jake Kozlowski's :rolleyes:
what is this part called in the coil spring ?
and how is it removed
Reactions: RHP61
Today I finally had the front 3.73 gears installed...; 2 weeks ago I could only afford to install the rear gears due to my budget. Today I also purchased and picked up a Bestop Spice Sailcloth Replace a Top with tinted windows. Need to wait for warmer weather to install...
Thank you STIMULUS....
