I was reminded that the cardon in the driveshaft needed to be greased occasionally after it started making expensive squeaking noises.,
What were the symptoms prior? Mine idles kind of rough despite new plugs and a recently cleaned IAC. It does it's normal start, which seems like it is .25 to .5 seconds longer than most vehicles.Changed the crank positioning sensor and she starts much better. Also idles better if that makes sense.
Replaced the fuel pump and the clutches in my rear differential.
Installed an Advance Adapters SYE and Tom Woods driveshaft. Took care of the vibe I had on acceleration.
Everything is smooth as can be.
View attachment 147145View attachment 147146View attachment 147147
It is definitely on my list of things to do. How hard was it with the TC on the jeep still?Installed an Advance Adapters SYE and Tom Woods driveshaft. Took care of the vibe I had on acceleration.
I did my SYE with the T-case still installed. It wasn't bad at all.It is definitely on my list of things to do. How hard was it with the TC on the jeep still?
X2.I did my SYE with the T-case still installed. It wasn't bad at all.
I like your clean work area.Not hard at all. I put the back up on ramps, and supported the tranny with a jack. I had a lot of room. I could sit up under there and work.
Definitely a good idea. Thanks youNot hard at all. I put the back up on ramps, and supported the tranny with a jack. I had a lot of room. I could sit up under there and work.
Love to get a sound clip of that muffler setupInstalled an Advance Adapters SYE and Tom Woods driveshaft. Took care of the vibe I had on acceleration.
Changed out my shocks. I’m now on team rancho thanks to the forum.
