I'm going to crawl under a rock now. Let me know when it's safe to come out.
Reading this I think you need to get your priorities straight because you cannot have it both ways.
Owning a wrangler needs a lot of care.
I really don’t know where I would be without your useless 2 cents bud.Reading this I think you need to get your priorities straight because you cannot have it both ways.
HAHAHHAYou just stepped on the hornets nest
You’re about to get chewed out and I’m grabbing the popcorn for this![]()
Ya I think it’s a combination of both but mainly the uneven worn tire. It happens consistently without bumps at about70km/h. If I hit a bump at that speed It’s not a fun experience lol Tomorrow I’m going to get the spare tire balanced and just replace the screwed up tire. I’ll check the suspension while the tires are lifted too to see if there’s anything out of the ordinary. I had a lot of the front end suspension replaced less then a year ago though...You can have both. Bad tires and loose components...that is likely on older vehicles.
A tire only can cause it , but the loose components allow it . If you hit a bump and that's all that sets it off , it's likely loose components that allow the shake ....but if it happens consistently at speed , it's the tire ...but in many cases the tire is part of it , and the components are, and the amount each one contributes varies , like a sliding scale . But it can be just one thing . Even just a low tire.
....any time the shake or slop is such it overpowers the vehicles inherent tracking ability , you get death wobble.
Cool, be safe up there.Ya I think it’s a combination of both but mainly the uneven worn tire. It happens consistently without bumps at about70km/h. If I hit a bump at that speed It’s not a fun experience lol Tomorrow I’m going to get the spare tire balanced and just replace the screwed up tire. I’ll check the suspension while the tires are lifted too to see if there’s anything out of the ordinary. I had a lot of the front end suspension replaced less then a year ago though...
Stay in your lane with the wobbly wheels!I really don’t know where I would be without your useless 2 cents bud.
That will work as a replacement. The bushing quality would be my main concern.Track arm doesn’t need to be anything special right? I’m not going to buy the most expensive but this ones fine ya?
Thanks Andy!!! I was just looking at the tie rod end ...so you can buy these bushings and just replace it on the arm? I’m going to do this then because there’s nothing wrong with the bar....both ends of the track bar though you wouldn’t believe the movement just grabbing it and pulling up and down/ in and out ...insane. No wonder
Just remember the bushings in the one you have are replaceable ... And you can get better bushings or upgrade to a JK bushing with a larger Bolt if you need to.. I would not buy a new track bar unless I was really sure that my existing one was not going to hold bushings and needed to save the fuss of replacing bushings.
There are a lot of how high strength components on the market and they've got their place but it's the connection at the end that does the work for the most part... Some people will put on a ZJ tie rod and swear it made things better but what fix their jeep was the new tie rod end that came with it.
To give you a frame of reference... If you can move that thing by hand that is absolutely off the charts... It normally takes the resistance of a 3500 pound Jeep to see anything.Thanks Andy!!! I was just looking at the tie rod end ...so you can buy these bushings and just replace it on the arm? I’m going to do this then because there’s nothing wrong with the bar....both ends of the track bar though you wouldn’t believe the movement just grabbing it and pulling up and down/ in and out ...insane. No wonder
Holy cow. I have never seen anything close to that loose... Give you an idea just a soft bushing moving 1/16 or 1/8 inch too much will give you death wobble... There is no question that if you fix that and put on better tires things going to be significantly better.Which one of you awesome men suggested it being the track bar?!
I know I’m excited to do it tomorrowHoly cow. I have never seen anything close to that loose... Give you an idea just a soft bushing moving 1/16 or 1/8 inch too much will give you death wobble... There is no question that if you fix that and put on better tires things going to be significantly better.
The bushings have to be driven out but they're not in too tight you can usually do it with a bench clampI know I’m excited to do it tomorrow. I been driving my Jeep for the past year with such a wobbly steering wheel lol. I just got use to it I guess. such a easy fix to improve it.
Just need to fix my electrical problem with this fuel/oxygen issue ....![]()
You have four bolts right they're coming off where the manifold meets the two catalytic converters... What typically happens is the fitting where's a little bit in the bolts corrode and lock and feel real tight but you're getting an exhaust leak that sucks in fresh air... By the Venturi principle... That confuses the oxygen sensors and they give the computer weird readingsMy exhaust isn’t loud no. I cut the rear cat off a couple month ago and replaced it with a straight pipe( it was loud then). Put the rear cat back- not loud anymore. The other week while driving something hit my floor and all of a sudden my exhaust was roaring — looked at the exhaust and one of the bolts I put in place of the 02sensors blew out lol
explain the ticking you’re talking about— where would it be coming from?
