Interior Maintenance Restoration and Repair
bedhed
Florida
This thread is for all things related to the maintaining, repairing, restoring, cleaning, and parts replacing of our TJ's door and trim panels, consoles, carpet, seat covers, roll bar covers, etc. Hopefully a one-stop thread for many questions that come up. I know there are some things related to sections here that are floating out there in the forum. I've found some and shared their links in the related section, but I'm guessing I haven't found them all. If you have, or know of any that aren't linked here, share the link.
To keep you from having to scroll through to find new info, see the layout below. It will show the date that it was last updated, and what was added.
Restoring, Refinishing, and Repairing
Restoring: updated 2/21 new
Refinishing: updated 4/5 Two-tone color codes, Member projects
Repairing: updated 2/23 new
Parts Replacements and Preventative Maintenance
Replacing Parts: updated 2/22 new
Parts Alternatives and Sources: new 2/23
Preventative Maintenance/Cleaning and Detailing: updated 3/5 What NOT to do
Restoring:
In some cases where trim panels have begun to have a white, chalky-like surface, some have had success in using baking soda to bring back the original surface and color. Baking soda acts as a mild abrasive for removing that chalk-like top layer. With many ABS pieces, the plastic is dyed to the color that we see. So, in some cases, just because the panel appears faded, the fading may not be very deep into the plastic. Using abrasives like baking-soda on trim panels is similar to color sanding auto-body paint. Clear-coats fade, but color sanding removes that damaged top layer, returning the exterior to a new look. Unless of course the damage is too deep. In that case, the surface will need to be refinished. The same goes for our plastic panels.
Watch the video below to see how this guy's TJ dash turned out. Night and day difference!
Restoring with Baking Soda
Thanks to @moab for sharing the video link.
Member project links:
Door panel restoration using baking soda
@Bionic_Scorpion
**More restoration info will be added as we get more. Share what you've got.**
Refinishing:
If restoring has failed or you just choose to refinish your plastics, spraying them with a quality color coating can bring great results. Me personally, I would go this route when there are no other options. The reason I say that is because it applies thin layer of great, but easily damaged paint. Easily damaged compared to the solid colored plastic.
I have only used SEM Products for painting automotive panels, and I can say that they have some great products.
Some other available brands:
  • ColorBond LVP - General colors and limited options
  • Duplicolor Vinyl and Fabric - General colors and limited options
  • VHT Vinyl Dye - General colors and limited options
With some paints, they can also be used on pliable surface also. Surfaces like, vinyl and fabrics. Even when used on these surfaces, can give great results that will have the material looking nearly new. Your results will weigh heavily on the prep work done prior to painting.
As for the SEM Products brand, for some of the older colors codes of our Jeeps, visit their Classic Coat products. For all others, go to their Color Coat products. If you don't know the color code for your TJ, you can look your Jeep's label to get the code. The label should be located in the driver's door jamb.
Here's a picture of mine as an example:
In this example, my trim color code is J3.
You can also visit AutoColorLibrary to help you pinpoint your code, as well as other interesting data on OE colors used around your Jeep. Note that, unless specified, the colors shown in their library are colors used by Chrysler, on other models of that year.
If you are still having troubles in finding the specific color that you need or want, visit the "Formulas" section on the SEM Products website. From there, you can either choose to see codes by year or see color cards. On that same page, you can select to download the formulas themselves. That can be taken to a site that does custom mixing.
Example from Formulas download. Search PDF file for key words if needed.
Side Note:
Don't trust the color seen on the cap. I spoke with one of the guys at SEM Products who advised to not rely to heavily on the color of the cap. Reason being is that the caps are sourced out to another company, so the colors that are infused into the cap's plastic is only their best effort at matching the request from SEM Products.
Chrysler Color Codes:
The listed codes are from those that were used in the TJ and in other Chrysler models. I've listed the additional colors to hopefully help clear up any confusion with mismatching paint.
AZ/LAZ - Agate (up to 2002)
C3 - Mist Grey (up to 2001)
J4 - Moss Green (up to 1998)
K5/RK5 - Medium Camel (up to 1999), Camel (1999), K4/RK4 - Light Camel (2000)
T6 - Saddle Tan (up to 1998)
DV - Dark Slate Grey (2002-2006), DB - Light Slate Grey (2002-2006), D5 - Medium Slate Grey (2004-2006)
J3/ZJ3 - Khaki (2003-2006), J8 - Dark Khaki (2006)
X9 - Landau Black
Chrysler Two-tone Color Combinations:
Note: The color codes listed in the below image are those used in all Chrysler vehicle models. Within these, are the codes for our TJ models. You will need your color code to find it's corresponding custom-mix product number.
Click the image to view larger.
If any of the info on color codes is incorrect or missing something, let me know so I can update or change what I have.
My personal observation of Landau Black:
I know that Landau Black was used by Chrysler, but I can't recall the info showing when and where they used it. I believe that it was used for the "black" trim bezels in some (or all?) of our TJs. Here are a couple of images showing the color and why I believe that it was used for that purpose.
Judging a color by looking at it on a monitor is always a bad idea. Most especially when the color is represented by another site or company. I kept that in mind and pulled these three different versions of black from the website for SEM Products, then adjusted the saturation to bring out the colors that aren't always easy to see. Landau isn't quite as dark as the other blacks, so it tends to show it's blue undertones in brighter lighting. It also doesn't have the red undertones that other blacks have either.
Here is a close-up of my center dash bezel. With the bright light on it, a clear difference can be seen between the black color of the bezel and the black color of the controls.
One more. Here's a picture I came across that shows an entire color change that someone did, using Landau Black.
In some projects that I've done, I've sprayed parts black, but the black turned out to be too black. I think the Landau looks really good in there, even with it being sprayed everywhere.
More details on Black colors used by Chrysler: See page 4
Prep and Paint
Products and/or Tools:
  • Dawn dish soap
  • Basic cotton rag or Microfiber towel
  • Isopropyl Alcohol (I've also used Windex with success. Be sure that it contains Ammonia)
  • Scrubbing pad (important details on Scotch Brite and similar pads below)
  • Nylon scrub brush
  • Paper Towels (Those least likely to leave lint behind. I prefer to use blue shop towels)
  • Tack Cloth (for removing lint and/or free-floating debris) optional
  • Adhesion promoter (list below)
Adhesion Promoters:
SEM Products "Sand Free" #38363
  • Unique wet-on-wet adhesion promoter for ABS, PVC, and similar plastics.
Note on other adhesion promoters:
SEM Products "XXX Adhesion Promoter" #77723, SEM Products "Plastic Adhesion Promoter" #39861, and Rustoleum Primer Adhesion Promotor #251572 are advertised as being best for olefin based plastics, and have no mentions of other pastics. Despite some of our plastics visually appearing (to my eye) to have some sort of infused polymer, I have not seen any parts that were stamped as being made up of such. All that I have seen, thus far, is stamping that shows them as being made up of either ABS, Polycarbonate and ABS blend (PC/ABS), or Polypropylene (PP). So, I'm not 100% sure on their effectiveness/longevity on our plastics.
Chemical Alternatives for precleaning:
SEM Products "SEM Solve" #38373 20 oz. Aerosol
  • Effectively removes adhesive residue, wax, grease, road tar, oil, silicone, paint overspray and bug remnants
SEM Products "Plastic and Leather Prep" #38353 16 oz. Aerosol
  • Removes mold release, fingerprints, grease and oil
  • Promotes adhesion of topcoat
  • Will not soften or distort plastic parts
SEM Products "XXX Universal Surface Cleaner" #77771 Quart
  • Helps eliminate static
  • Exceptional grease-cutting power
  • Multifunctional for primed or painted surfaces, leather, vinyl, plastic, aluminum, and bare metal
1. Thorough prep work for painting plastics is critical! When you think you have prepped enough, just do it again. It's better to put in a little extra prep work now to prevent poorly bonded paint. The time spent prepping will seem like a walk in the park when everything begins to have flaking paint.
2. Clean the surfaces using a rag, using warm (if possible) water and dawn dish soap. It wouldn't hurt to go back over the entire panel with soap and water, but this time using a soft to medium bristled scrub brush. No metal bristles. Nylon bristles.
3. Repeat the same as above, only this time use a fine grit scotch-brite pad. Those that are blue in color and sold for general purpose household cleaning will work, or you can go to Home Depot or Lowe's and pick up the grey pads. The grey pads at those places will have a label, from fine to course. For this you will want the fine grit. Be very thorough when going over the panel, covering every inch, and getting into all of the corners and tight places.
4. Let the piece/s dry, then use your choice of (safe) degreaser to wipe the piece down, using a microfiber towel, or blue shop towels. We're looking for something that won't leave "lint" or fibers behind. I have used both Windex(with Ammonia), and Isopropyl Alcohol and had good results. Just no harsh chemicals that will damage the plastic. Be cautious with touching the surfaces with bare hands, so you don't leave any oily prints behind. Probably not a bad idea to throw on some latex or nitrile gloves.
5. If you have access to compressed air, this would be a good time to make sure there are no hidden puddles of water in those tight places. Place the panel in the area you plan to spray, making sure it's at a level that you can easily spray without difficulty. This is a personal preference, but it isn't completely necessary. At this stage, I like to use tack cloths to wipe down the piece before spraying, to remove any lint, cloth fibers, hairs, etc.. Even if there is something left behind, with this paint being as thin as it is, and drying as fast as it does, it's amazing what you can easily wipe off before your next coat.
6. Next, it's a good idea to use an adhesion promoter. If no areas are in need of being masked off, go ahead and get both your adhesion promoter and color shaken up and ready. First coat will be the adhesion promoter. Adhesion promoters and their drying time are different, so follow the instructions on the can. When you're making passes with your color coat, make light coats. SEM paint isn't heavy, so going fast isn't necessary. Just make sure that each pass is putting down a light coat. Follow the instructions on dry time, then return with more light coats. Repeat until you are content with the results.
Note on chemicals and plastics:
Here's a helpful chart that can be of use prior to repairing plastics, or prior to prepping plastics for paint. In the case of cleaning or prepping for paint, taking note of how a specific chemical's effect can prevent unnecessary damage. When doing repairs, this can also be of use. As I mention later, you can make these "severe effects" work in your favor.
Since ABS, PP, and PC are the plastics that we will be dealing with, I have modified the chart a little, so as to make it better suit the thread's purpose and make it easier to read through.
Click the image to enlarge
Confirmed Colors
J3/ZJ3
- Khaki (2003-2006):
- SEM Products #5545 (Must be custom mixed). Thread Page: 3
- SEM 15833 is commonly referred by sales reps. for our TJ, but this color is not correct. 15833 was a 2008 color.
DV - Dark Slate (2002-2006):
- SEM Products #17373. Thread Page: 3
https://wranglertjforum.com/threads/sahara-interior-color-code.6561/post-490869
Product Sources
Vinyl Pro (Atlanta, Georgia - You can call them with your SEM "Trim Color Formula" number and have it shipped to you in an aerosol can. They are a large distributor of SEM Products, and carry the full line of products at great prices.
Door Panel, Dash, and Bar Fabric Refinishing @Tjs TJ
SEM Khaki used to refinish door parts. Pages 1 and 2. @MountaineerTom
PPG Products Agate, used on various interior plastics. Page 3. @TJRick
Color Bond (Ford Black). Thread Link. Completed interior @Lilbomb
Color Bond, used on various interior parts @DuncLJ
SEM Landau Black, with Low Luster Clear. @mrblaine
SEM (custom mixed) Khaki used on door panels. @Rick deCastro
SEM 15173 (Camel), with SEM 13023 Low Luster Clear used on various parts. @csierra88
Repair:
As of now, I know of two parts that are notorious for problems. The crash pad and the door panels. The crash pad/defrost vent cover in our TJs becomes very brittle with age. Once the plastic reaches a certain level of brittle, one tap from a finger on the vent guard "bars" and they break. There are several ways to tackle the fragile defrost vent problem. You'll just need to choose what material, plastic or metal.
Here are some ideas and/or options used by others:
Metal Rain Gutter Guard at Home Depot or Lowe's
PVC Coated Plastic Chicken Wire Mesh on Amazon or other online sources.
Expanded Metal at McMaster-Carr Supply, or simply search online for Expanded Metal.
Wire Cloth at McMaster-Carr Supply, or again, just search online for Wire Cloth.
Depending on the severity of your broken vent guard, you may be able to get away with adding some structuring on the bottom side of each plastic "bar" by using some type of adhesive, like Epoxy. That can be found in easy to use syringes at any hardware store. You can also use a combination of metal rod or solid core wire secured to the underside of the grill pieces using Epoxy. Considering this method for your repair means that you are one of the lucky few that still have the majority of your vent guard remaining.
If you haven't seen it yet, here's the underside of the crash pad:
Like many, if not all of the interior plastic panels, the crash pad is made up from ABS plastic. On the positive side of this, ABS is really easy to work with.
You can use a heat source for removing the vent deflector from the underside, as well as for bonding your new guard onto the trim panel. Using a "plastic welding kit" will be the least destructive method for removing the vent deflector, because it retains the material to be used later, unlike cutting or grinding. The same goes for reinstalling the deflector. If that type of tool is used, you can reheat and shape the retained plastic to better secure the deflector into place. You can purchase a plastic welding kit at most hardware stores. They are essentially just a soldering iron that has removable tips that are designed for cutting, shaping, and bonding plastics. If you're careful, using a small butane torch for your heat source, along with something like a flat-heat screwdriver to achieve similar (if not identical) results.
Adhesives can also be used, like the epoxy mentioned earlier. Again, epoxy for bonding plastics can be purchased at any hardware store, among other places. Since we're working with ABS, it won't require any specific or uncommon off-the-shelf epoxy. Another adhesive that I like to use for nearly any project is Cyanoacrylate, aka CA Glue, or Super Glue. The best way to use CA glue, IMO is to use the two-part method, which requires the adhesive to be sprayed with an activator before it will harden. Something like this kit on Amazon. Using this method not only helps control the drying situation, but it causes the glue to harden in less than 2 seconds. Best of all, this method prevents your plastic from being stained by the fumes of slow-curing CA glue, leaving a small to very large white power looking haze on the plastic. An alternative to the two-part CA glue involves baking soda, again. If you choose to go with common CA/Super Glue instead of the two-part method, you can greatly increase the curing time and prevent the staining white haze, just grab up a little baking soda between your fingers and sprinkle it over the glue. The downside to this is, when the glue cures, it has very rough, rock-like feel. Not a huge problem though, just sand it down if needed.
Another one that I like to use is one that can be made at home and make for any very strong bond. What it is, it's basically liquid ABS plastic. I use a glass jar that I started by tossing in scrap pieces of ABS plastic. If you don't want to use glass, you can use plastic, just make sure that it is stamped HDPE. With my ABS-filled glass jar, I pour in some acetone. Acetone can also be purchased at any hardware store, and is useful for many projects. After you have poured in the acetone, close the lid and you're finished. Let it sit. Acetone very quickly begins to liquify ABS plastic, which will have your container left with a liquid form of the same material as many of your trim pieces. You can control the thickness of your ABS slurry by simply letting the acetone evaporate out, or pour more in. It's that simple. Using this ABS slurry between two pieces of ABS causes the solution to liquify the surface of both parts, leading to a fusing of the two.
Methyl Ethyl Ketone (MEK) also works very well, but evaporates much more slowly. If a slower drying time is what you prefer, MEK can tpically be found at the same location as the acetone. On a side note, if you want to use acetone for small projects, and don't want to buy a large can, "Professional grade Goo-Gone" is sold in small, lighter fluid-type cans, pint sized cans, and aerosols. Just check the ingredients to insure that the one you are buying contains acetone.
Repair ideas and suggestions
- "How To Repair Scratched & Gouged Interior Trim & Match TEXTURE Perfectly!" (Youtube video): Page 2
If you have any adhesive recommendations, share them.
Member Project Links:
Broken Defrost Vent/Crash Pad @Equilibrium31
Upper Door Panel Crack @AndyG
Upper Door Panel Crack @TJ4Jim
Upper Door Panel Crack @Tjs TJ
Replacing Parts:
Sources for used parts
Car-Part.com, Davey's Jeeps and Parts, Forum, ebay, Craigslist
There are definitely other sources. We can update the list when those source names come to mind and are shared. You can also watch this thread "Looking for used parts for your TJ?" to get notifications on any new sources.
Sources for new parts
Many dealerships also sell parts online. Searching for Mopar parts will bring up several sources for new parts. Here are a few that I have used many times, and have no complaints. Try checking the Mopar sites for contact info. From there you should be able to pinpoint what dealership it is that is selling the parts and their location. That may help in finding one closer to you and reduce shipping cost.
Mopar Parts Overstock, Mopar Online Parts, Rock Auto, Mopar Parts Giant
Remember to check another source for pricing. I've recently bought from one of the dealership sites that had a cheaper price than Rock Auto.
Parts alternatives and Sources
Stop/Bumper - Glove Box Door (Part Number: 55315051AA) Page: 2
- Dorman GM Rubber Bumper Assortment (Part Number: 961-375D) Thanks to @GaTechTJ
- If those become unavailable, alternative "Button Bumpers" can be found online for 0.25"(1/4") OE hole diameter.
In my opinion, our plastic trim pieces require the most attention when it comes to preventative maintenance. With these parts being constructed from ABS, their continuous exposure to the elements makes their deterioration inevitable. When these plastics aren't routinely cleaned, those surface contaminants can act as catalysts for excited deterioration of the plastic. Basically, these interior plastics deteriorate fast enough as it is. Not routinely cleaning them only makes that worse.
The sensitivity of polymers to UV radiation:
(Click the thumbnail to view the full image)
Cleaning Products
Meguiar's® Ultimate Protectant, G14716, 15.2 oz., Spray
Meguiar's G17914 Gold Class Rich Leather
Folex Carpet Spot Remover, 32 oz
Tuff Stuff Fabric and Carpet Multi-Purpose Foam Cleaner (22 Ounces)
BISSELL Little Green Pro Heat Carpet Cleaner
I don't routinely detail my interior. I've actually gotten pretty lazy with cleaning it at all. But, when I do detail it, I'll start by pulling out the air compressor and blasting off the brunt of the dust and dirt, while making sure to hit all of the little cracks and crevasses. After that, I use a mildly fine-haired detail brush to go back over all of the little cracks and crevasses, around the radio's buttons, air vents, etc.. After that, I follow up with some off-the-shelf cleaner and protectant. For the plastics and steering wheel leather, I've been using Meguiar's Products that I've included below.
As for the carpet, I have used Tuff Stuff (link listed below) for over 20 years, and I can honestly say that I have only come across one stain that it didn't remove. Although, I have recently been using Folex Carpet Cleaner and I have been very pleased with the results. It works extremely well for stains.
Carpeting
As we get more details on other methods, we can update this section.
Depending on the level of carpet detailing that I'm doing, I do the following:
1. Using a combination of a vacuum and nylon scrub brush, I use the brush to lift the fibers of the carpet and bring any embedded sand to the surface. Then vacuum the carpets, entirely.
2. Coat the carpet in a layer of Tuff Stuff or Folex and let it sit for a couple of minutes. Afterwards, I go back over the carpet using the same method as before, using the nylon brush. Any dirt and/or sand that was previously left behind will be brought to the surface to be vacuumed out.
3. With the newly brought out sand and dirt, I will vacuum the carpet once more. For areas that see more foot traffic, or other light stains, I repeat the process with applying the foam later and following up with the scrub brush.
4. After all has fully dried. I spray a light coat of Scotch Guard (link listed below) over the fabric.
If I am doing a more thorough carpet cleaning, I will skip that last process and use a portable extractor. I have been using one made by Bissell that works very well. I've put the link to it in the list below.
Fabric Seats
With my seats, I only use Tuff Stuff or Folex for spot cleaning. Again, depending on the level of attention/effort I'm putting into cleaning the seats, I will either vaccum, then spot clean with Tuff Stuff or Folex, or I will break out the extractor. Just as I do with the carpet, once the seats have fully dried, I spray a coat of Scotch Guard over all of their fabrics.
I'm no professional, so take this info as you will. If you have any suggestions or methods, please share.
It doesn't sound like it from what I've described, but I do enjoy detailing. I oftentimes watch the "Car Cleaning Guru" on YouTube. If there are any videos or websites that you feel will be helpful, share that too.
It's been a while since I've read into different products and their efficacy, so I don't have a specific brand to recommend. The most important would be it's ability to protect from UV rays. For my personal preference, what is equally as important is for the product to not leave everything with a glossy shine, nor an oily residue. Both of the Meguiar's products check those boxes, so I have continued to use them.
What NOT to do:
  • Using ammonia or ammonia-based products, like Windex (unless labeled as being ammonia-free) can damage some plastics, stripping them of any OE films, and/or cause small fractures in the plastic.
If you all know of any good products, ideas, or methods for this section, let me know. I'll add them here.
Anybody happen to have the paint code used for the silver dash panels on a 2006 LJ. I got close with a duplicolor but it’s not quite right.
I have all of the files still up. I seem to remember seeing it somewhere. I'll look and see if I can find it.
Not sure if I’m reading it right but I see what I think is the door code but I don’t see that silver color of the dash anywhere.
I looked back at that page and I wasn't seeing anything either. I'm looking one now that I'm wondering about.
CDK Stainless Steel Metallic (Only used in 2006)
I searched the SEM Formula Sheet for CDK, but it only came up with one, and it was for a Ford. Oddly enough, it does have "stainless" in the name.
that could be it, the Ford part is confusing though.
Reactions: bedhed
Dang... great job on this how-to thread so far, I'm impressed!
This is one of those threads I didn't know we needed, but now that I look at it, it's obvious we do need it. Tons of great info here!
I don't see a video link, but I'm assuming you're still working on / editing the original post.
Reactions: JMT and bedhed
Yeah it is. Maybe that color will be closer. I struggled with locating any info on that color in yours. The closest thing I found was useless really. In a spec list, it said "Metal-like Trim Color". 😑 thanks
Thanks! I don't think many of us have thought a whole lot about it. They're getting up in age though! I've got to get my ass in gear and fix my door cracks and dash myself. I've been procrastinating.
Do you mean the baking soda video? That's the only video that's in there so far. Anyway, the link is imbedded in the wording. I'll make a note above it.
Yes, I fixed it for you.
Instead of making a hyperlink to the video, just copy and paste the video link below the text (see what I did above).
That way it embeds the video directly on the page, so someone doesn't have to click out of the site. Make sense?
Either way, keep up the good work, this is a great idea for a thread.
Reactions: bedhed
Great post! A lot of great info in one place.
For reference, the SEM paint for Khaki J3 interior is SEM Color Coat 15833.
https://www.amazon.com/gp/product/B00B3HXUIS/?tag=wranglerorg-20
I’ve painted a few small pieces like the push in plugs for half doors and the grommets In the top of the door for the soft upper frames and the color matches my full door khaki panels really well. I still need to paint my panels though.
Reactions: zebra12 and bedhed
I thought more about that link last night and intended on changing it up. That's much better!
How well did the match up for you? I ordered some a few months ago, but haven't gotten to my project yet.
You're killing me with the yellow and grey / white text. I can't even read it at all on my screen :ROFLMAO:
You're a designer... you should know better ;)
Reactions: bedhed
:ROFLMAO: Damn. Now that was funny! For what it's worth, that AND the all white route have been bugging the hell out of me. I have no doubt that you'll come back and see different colors at random times lol.
All black text is the way to go. In fact, one of my biggest pet peeves in the web design world is when people use any other color than black text for body type (unless it's on print work).
On the dark theme I'm sure it shows up, but on the standard site theme, you can't read that text at all without running your cursor over it.
Reactions: bedhed
Thanks. I'm glad it's helping.
😆 I saw that. I didn't think about that until you mentioned the bright theme. I checked it out. That was terrible. All one color now.
Yep, if you remove the colors entirely it will use the default colors, which will then work well on both light and dark themes 😉
Reactions: bedhed
I don't recall the use of adhesion promoter or UV protection in paint in your write up. If you did my apologies. I used adhesion promoter on my flares. And several other parts on the interior. It's highly recommended by several advanced painters and SEM themselves. Possibly other manufacturers. Also SEM comes in different versions. And only some of their paints are UV protective. I'm sorry I don't recall which ones. This would hold useful for almost all the interior plastic as it all gets sun damaged. At least along the top of the dash and door panels. I think there is a clear coat range of SEM products that contain UV protection. So you can also do a flat or satin clear coat over whatever you paint. And most suggest doing so anyway.
Replacing the seats is an easy solution to old worn out ones. As long as you use the original brackets you can swap to and from early and late model seats. Except for the rear. Different brackets in the tub between the two. You may also want to mention the use of Tiberon or other seats. As well as good aftermarket brands. Forgive my overworked brain. I worked 23 hours yesterday. And am wrecked. I don't recall the brand name of those aftermarket seats everyone loves. It's not PPG but some acronym like that.
You might want to also mention the use of Misch Big Boy brackets and/or seat lifts. When I say seat lifts I mean those metal or plastic blocks that you can put under your seat to raise them. I don't use them as I'm 6'3". But many do. I do use the big boy brackets and they are a life safer for those with long legs.
I did a write up on ACC carpet a while back. I'll see if I can find it. There are a bunch of how tos and posts on Bedrug etc. But ACC is by far the thickest pile you can get. Which ads insulation and better wear over time. And just a more luxurious feel to it. And it's way cheaper than the Bedrug. Not good for hosing out though. ;)
Also @Chris 's write up of Noico sound deadener. There are a couple good write ups about sound deadening. But I think Chris's use of Noico products was spot on. And he took great pics of the outcome. Had Noico been around (or I had known about it) at the time. I would have bought Noico. Sound deadening is a great option for those of us that don't have to hose out our tubs. Again...;).
That's about all I can think to possibly add off the top of my head. Sorry I wasn't more specific with links and such.
Reactions: bedhed and Chris
