I’ve ordered a light bar for my 02 TJ that fits around the windshield with 4 mounts for lights. I’m wanting to put 4 KC 6” slim fit lights up there. What’s the general consensus as far as using spot vs the flood/spread pattern above the windshield?
Did you get these installed? How do you like them?I’ve ordered a light bar for my 02 TJ that fits around the windshield with 4 mounts for lights. I’m wanting to put 4 KC 6” slim fit lights up there. What’s the general consensus as far as using spot vs the flood/spread pattern above the windshield?
I'm still trying to figure out what I want for off-road lighting. The brush is high right now and I'm trying to add some light from above (probably going to eliminate the hood light bar). I had 2 Warn Halogen Spots mounted by the mirrors, but with the cheap light bar the halogens weren't noticeable. I'm leaning toward getting a low profile ~20in combination flood/spot light and putting it up top in my rack. I could then do some lights to the sides of the front of the rack and then there's lots of mounting options 360, but reverse is pretty bad at the moment. I have some LED reverse lights that aren't terrible, but not really good.I have the KC slimlite fog lights, and used Daylighter spot lights. They’re quite nice. I’d buy them again. I have the 100 watt bulbs in the fogs, which are almost too bright for on-road use. I have the 130 watt bulbs in the spots
They work really good so far. I went with KC Apollo brand; they weren’t as costly as the slim fit.Did you get these installed? How do you like them?
They look great. Also great license plate.They work really good so far. I went with KC Apollo brand; they weren’t as costly as the slim fit.
I'm KY born and raised, but I do dream of doing some hunting and off-roading out west.
I hate light bars, but if I was going to do one, it would be a mix of spot / flood.
Where would your location of choice be if you happen to go with spot/flood mix? Don't you want the spot lights to move around in order to "spot" things??? I'm just sitting here wondering what options there are....ticktick
tick...
As with anything, how do you plan to use them? Lights are a tool. Flying through the desert at high speed is different than crawling through rocks or timber. Decide how you want to use them and that will dictate what you need.What’s the general consensus as far as using spot vs the flood/spread pattern above the windshield?
That sounds like some good research. We don't have much desert or snow here. Does anyone have suggestions for whiteout conditions? I remember we had that happen a few years ago and we don't shut down unless we don't have power, so it was very nerve racking driving on what I was guessing was a road, with massive ditches on either side.I've been researching on lights and it's hard to decide what light sets to get. I like to explore my area I live in the desert of El Paso, TX , also I go to NM to camp and explore the trails. Now here is my question, what type of lights would be good to drive in the desert (not at high speed) and drive around the trails in NM that really doesn't have much dust just depends on the area?
Here is my understanding on driving in the desert, snow and fog. It depends on placement and color. I believe amber is the best to go just because white light just reflects on the snow, dust and fog. Being a truck driver in the Army we experiment with different lights since the actually light on military vehicles sucks. So we try to put brighter lights and a lot of them we used KC lites on top of the vehicles so we could illuminate the whole road checking for IED's on the grille we used fog lights amber so when we are driving and picking up dust from crossing the desert we could see better and on the pillar we use spotters.
Do you guys think that would be good setup for the TJ or do you have any other suggestions?
