I’ve had a problem with my 2000 Jeep Tj 2.5l overheating when I turn off the ignition.
When I’m idling, revved up to high rpms, on the interstate, or any other situation where it’s turned on, I have zero issues with overheating. It stays right under the middle 210 mark (so maybe around 180-190) when running, with minimal fluctuation.
The moment I turn it off, it begins rising 30-50 degrees over a few minutes.
When I start it back up again before it has had time to cool, it starts up very rough. But if I let it cool, it starts up beautifully.
So far, I’ve replaced the radiator, hoses, cap, thermostat, and flushed the new radiator and refilled with zerex G05.
The coolant level has stayed the same and there doesn’t seem to be any leaks.
I do not believe the radiator is a mopar, but it seems to do the job when it’s running.
I also put a small clamp on the overflow hose because it seemed a little too loose on the radiator side (it even slipped off once while off-roading). There seemed to be a few drops that would trickle down the radiator and steam/smoke when it would overheat, but not since I added the clamp.
What might the problem be? Fan? Pump? Head gasket? Let me know what what I should look at first.
I’ve already taken it to multiple shops for this issue—the last shop put in the new thermostat, which didn’t change anything.
I did have a slight overheating problem before where the AC would cause it to overheat some. This is no longer a problem.
