Drove over to ID today and picked up (6) 15x10 wheels with (6) 35x13.5r15. It doesn’t get much better than this. However, not sure these will see the Jeep anytime soon.
They are much bigger than 33s
Angled rear trackbar bracket came in from @Kris M . It appears to be brand new! Very kind of you! I hope the mounting simply replaces the old relocation bracket.
How long until you go to the Currie 4" for clearance?
This is a little bit of an experiment. My wife loved the big tires. I’m not convinced. The tires are sticking out so far, but I see why the backspacing on the 15x10 rims are 4”, to keep them out of the CA’s. I will probably stick with 33’s
I wondered how long it would take you.
Only one day and I had to put them on. 🤣 I drove it up to 50mph. Tires need balancing.
Yeah 13.50’s are a little wide I run a 17 x 9 with 3.50“ bs and a 35 x 12.50 tire this was my set up before the MCE fenders only 4” total SL and no BL
The old wheels had 4” BS
Reactions: TJ Starting and JMT
It’s a Currie bracket on the bottom they say to weld it. For as many bolts as that has I’m not sure that would be mandatory.
Hmm...yeah, I just read the install instructions, last step is to weld the two tabs to the axle tube. Seems you could run it for awhile till you happen to run into a welder.
