I’m not sure how to disconnect the transmission cooling lines from the radiator. I don’t want to break something that I will need to use again.
What year do you have?
Does anyone know what the differences are between the 00-04 and 05-06 radiators are? If it's just the transmission fittings that can be unthreaded and changed, I'd like to have just 1 as a spare on the shelf than one of each.
Just found this, I think it will work2005
Got itJust found this, I think it will work
https://wranglertjforum.com/threads...-transmission-line-fittings.16966/post-276393
Is there anything similar to burping that needs to be done for the transmission fluid?
Do we know about how much transmission fluid is contained in the radiator? I’m about to refill mine after the rad change, don’t want to over do it.
Thanks. I had also nearly emptied the Derale cooler when I took it off to fix the fittings, so I went ahead and added a quart. After running for about 20 minutes in park, and after cycling through all the gears, I checked the level with the dipstick and it was showing up in the Cold zone. I’m not sure if Cold and Hot on this refers to the engine temp or the transmission temp, but at this point the engine was sitting at 205. The trans was at least below 180 because the Derale fan hadn’t kicked on and I hadn’t driven it anywhere yet.Probably about 1/2 qt. It's common to overfill the 42RLE transmission by a quart so you'll be safe as long as you haven't already overfilled.
I can’t tell from the pic, but did you slide the hose all the way over that ridge on the front of the t-stat housing and clamp it below the ridge?
It’s my understanding that the hose only goes down to the first ridge with your clamp being placed between the ridge and the end of the t-stat housing.
I found mine on Rockauto and it was about $50 cheaper than Amazon.My radiator just cracked last night and I purchased a warranty on my 99 jeep wrangler sport last year when I bought it. Should I have it replaced with my warranty or do the work myself? I enjoy working on my jeep but I seem to be having trouble finding a mopar radiator. I used the links provided but it says the radiator won't fit my jeep. Thanks guys! I attached a photo of my radiator too.
Is that leaking from yet hose?Here is the one in Mark's rig that is very high dollar. They won't even consider a replacement until we remove it and send it back to them.
If it ain't broke don't fix itI installed a new radiator from Jc Whitney a decade ago no problems yet.
With my experience being a car mechanic I see the new water pumps have more play in the fan bearing than the one I took out. I tend to leave the orginal water pump in there. On my '79 Chevy suburban project I rebuilt the 350 v8 at 88k the orginal owner spun a main bearing. Luckily at the time I stripped three trucks for extra parts. I drove the rebuilt engine another 100k with the orginal pump.
We played with new thermostats too to see at what temp they opened. There all different too.
My moto is if it ain't broke don't fix it. I was like you once too I changed water pump, all the hoses, radiator, too.
This is what happen to me this week and what I see most on the internet.This happened tonight; absolutely hilarious in my opinion because two months ago I was worried about those cracks in the top of my radiator:View attachment 17023
Loctite weld from Kroger:
Kroger parking lot:
