Should I buy this Ford 8.8 axle?
I like my rubi 44. Bolt in, not offset, and is plenty strong for what Ive done so far. I need to address a few clearance issues on it though (lower shock mounts). Ive dragged the center diff enough in its current state, the 8.8 would be have held me back plenty. When talking jeeps, I think every fraction of an inch counts, not only in suspension travel, but building too (tummy tuck for example)
Reactions: jtf440 and jjvw
How useful is this additional strength provided by the 8.8? Again, what real world problem with the Dana 35 is being addressed by moving to an axle with stronger tubes?
Lower gears in the Tcase, wide chain upgrade, and the beefier planatiaries could easily add more torque being applied to that rear axle pinoin, ring, axles, and tubes....
So I would say it depends on what you are building your Jeep for. Where you will be wheeling it, West Coast seems to be set on 35s and Dana 44's and youre setup for even some of the more hardcore trails. Deep in the South, where wheel spin and V8 Swaps are common, you will need bigger tires and beefier axles for teh wet slippery rocks.
IMO either option is good. All that really matters is its out in the woods wheeling. I would rather have an 8.8 over the Rubi 44/35.But a Gen 2 Dana 44 is more desirable over both the 8.8 and Gen 1 Dana 44/35.
I see you Alabama! You know!
Do you run a Dana 35 or 8.8?
Have or did you broke anything on the Dana 35?
Back when me and my brother ran Dana 35s on stock internals, I broke a set of spider gears trying to bump a rock ledge. My brother twisted splines daily driving his lincoln locked stock Dana 35.
While I don't buy in on the Dana 35 stuff, however, I do see that in some regions the Dana 35, when modded with $1500 worth of upgrades (Super 35) is an appropriate axle to run.
But IMO axle swapping and getting away from the Dana 35 is like choosing the 4.0L engine option in the Wrangler over the 2.5L. Sure, the 2.5L has enough power and torque for the Wrangler, but the 4.0L is an upgrade and is more than enough. Will you use all the potential of the 4.0L? Maybe not, but its nice to have, even if you dont need it.
Does that make sense?
The 8.8 vs the Dana 44; each has its pros and cons. It's up to the owner to chose which one he/she wants for his/her application. I have found that usually the 8.8 can be found much cheaper more easily.
W
Ahh okay. So what did you do once you broke the gears?
Upgrade or swap axle assemblies?
What size tire were you running?
I’m running a 35in tire and considering an 8.8 so I can wheel a lot harder.
W
And just like that.....
The upgrade reason and tire size was finally revealed!
