Okay so I got the Jeep more than a month ago. Jeep Wrangler 4.0L 2000, with about 140k on it. Two weeks after I got it, it started to overheat on idle. My mechanic said it was the radiator, so we replaced that along with the fan clutch and thermostat. That seemed to solve the problem. It was good for two weeks. However yesterday the problem was back. Overheating at idle again. Drove it to the shop. Mechanic opened the radiator cap with no gloves and as it being hot and pressured, he let go and ran away causing it to spray coolant over my engine bay. Dumbass gets a hose and starts hosing down the engine bay to clean it, Jeep wouldn’t turn on after that. We cleaned the engine bay, properly and wiped it down and dried it with a vacuum and then it turned on. We added new coolant to the radiator, and it seems to be fine again however I am supposed to return tmrw to see if there is any leaks.
My question is, could my head gasket be blown? My uncle thinks it’s that and it’s been stressing me out. Any help is appreciated!
