What winch do you use?
Can someone tell me how are these control boxes mounted on the winch?
My winch came with the solenoids and I just picked up a ABS project box to get the solenoids in there however I am not sure how to fasten/support the box to the winch itself.
Which brand did you get? Was it new?
Generally they have some brackets that hold the box to the cross bars above the drum. You could just use some zip ties and it would be fine.
There must have been a time
when we could have said no.
I think your best bet is to contact the mfg'er for the specifics of wiring the sol. You may can get a box from them that will mount to the winch.
I have the wiring all figured out. The stuff works, I simply need to understand how the box is mounted. The parts diagram doesn’t go in great detail on this or how it’s done. I even googled the part number for the box without any actual success to figure out how it’s fastened down.
Thanks! Yah I figure it was some sort of bracket. Guess I’ll have to do some more digging to find out how it’s fastened
