I just want to circumcise myself with a die grinder.
Excuse Me What GIF by CBS
Dropped the tank to fix a misaligned fuel pump, EVAP leak and fuel leak. All these problems started after I installed a UCF tank skid. I was trying to prep for Moab and ran out of time. So I waited until I got home to fix it. The EVAP leak was a broken connector which gave out on a ledge at Top of the World.
The alignment of the pump doesn't have to be off much to interfere with the fuel gauge arm. I'm going to have to seriously counsel the installer.
And apparently I didn't get the pump seated correctly. Looks like my fuel leak, which only happened when I filled the tank to max, was the issue.
I smoke tested it to make sure there were no cracks or other issues. I'm too cheap to buy something I can make. Particularly if it is rarely used.
You could have used a cigarette to do the smoke test. :unsure:
