What have you 3D printed for your TJ?
Speaking of bad influences, I’d like some more guidance from the experts. Given I’m just getting into this, can anyone recommend a good set of filaments to start out with on the Bambu HD2?
I’m sure at some point I’ll get into objects which require more durable material, but certainly at first I’ll just be playing around with the thing. I’ll see all the grandkids over the Christmas holiday, and know LJ would love to see something printed for him.
Thoughts on materials and colors?
Thanks in advance.
PLA, at least in Houston, will warp and twist just being outside for 1 hour. I recommend PETG for just about everything. Works in the pool and in the heat of the outdoors.
Well, FedEx actually came through and delivered the H2C yesterday! I had been working on a couple models most of the day prior to delivery, so when it came, I unpacked it, set it up, and printed my models. Here's one (the light colored one), can you guess what it is?
Yup - a spare tire bumper. Still learning all the settings, so that's just with the default settings. I'm going to try printing it with a TPU top portion eventually - this was just a trial run with PLA. It'll have a steel insert (a repurposed type H drill bushing) pressed in so that the screw doesn't fracture it. I'll be posting more info in my build thread as I make progress.
I'm very pleased with the H2C. What a fun tool! Jeff, when Santa brings you the H2D, you're gonna love it!
Since the H2C arrived a week ago, I've immersed myself in the technology of 3D printing. I had to learn a whole 'nuther language! Also, I'm finding that many of the designs available on the various sites don't meet my standards, so I am designing most things I print from scratch, which takes a lot more time. Following up on my previous post, I've figured out multi-material printing and TPU printing (not as simple as other materials). Here's my finished spare tire bumper with a plug for the end:
I used PTEG HF for the main portion, and the top and bottom are TPU 95A HF, and I really customized the slicing. The top was TPU for some give against the tire, and the bottom was TPU because it works with the plug to seal the bolt and sleeve inside from the elements. Both filaments were thoroughly dried prior to printing. The TPU got slightly stringy on my at the very end of the print.
I plan to post more about my design process on my build thread when I get a breather from 3D printing.
How stiff / pliable is that, Scott? More like rubber or hard plastic?
Reactions: Apparition
I scrolled down your post and looked at the picture without reading anything. I thought you made some kind of heavy duty flask. 😆
Reactions: sab
As a designer for many years now, I understand and suffer a similar problem. (y)
In related news, my new hub and AMS HT arrived today. Just finished hooking everything up, minor hiccup as it seems I accidentally removed the 4-1 adapter from my order. I run non-AMS filaments from an inexpensive Sunlu dryer box, but that can't be ported through the BL hub. I used to use a 3d printed "Y" but found over time the PTFE tubes would tend to back themselves out of the ports, the couplers BL uses trap the tubes to keep that from happening. MIght as well order more filament while I'm at it... :sneaky:
Since I was well behind on printer firmware, figured it was a good time to address since I was adding new hardware to the chain. I can state the offline update feature in the X1C works without issue, all handled via a downloaded zip thrown on the SD card. The printer immediately recognized the file without any need for extraction.
Reactions: sab and Apparition
I didn't realize I needed the 4-1 adapter for the H2S until the HT came and I couldn't plug it in anywhere. It's coming today, but I won't be home for another five days. Hope nobody steals my $5 part off my doorstep. :cautious:
  • Sad
Reactions: lBasket
Just an FYI on the 4-in-1. My H2C came with a yet another new design. It has a replaceable wiper on the outlet side that cleans the filament before going into the extruder to prevent clogs and other issues. I have two AMS 2 Pros and five AMS HTs, so I need two of these. Right now, I'm using the new style that came with the H2C and one of the old style ones. I plan to get a second of the new ones when they become available on December 9, 2025, according to the listing in the store:
https://us.store.bambulab.com/products/bambu-4-in-1-ptfe-adapter?id=667312178471530496
It comes with five replacement pads, and the replacement pads are not available until the same day:
https://us.store.bambulab.com/products/4-in-1-ptfe-adapter-filament-ii-cleaning-pad
Convenient, I need a 4-1 adapter myself. Now I just need to figure out how to get to Florida
No worries, you've got 5 days to figure it out... :D
Not sure I'll be needing my 4-1 adapter now that I purchased it as less than 24 hours after having one AMS HT in the house, I decided to buy another one as a replacement for the Sunlu (so now can run though the hub). While it consumes ~3x the power, the HT does a damn good job of controlled drying. Heats up about 4x as fast as the Sunlu and can reach higher temps, plus it can rotate the filament automatically while heating/drying.
Since just recently having to dick around with inserting and removing PTFE tubes from the buffer and AMS hub, I whipped up a quick tool design to help in pressing the release buttons to free the tubes. STL attached if anyone wants to print one.
Seems BL is getting even more of my loot this week. I had a notify on ASA-CF and got hit earlier in the week, by the time I got the site it was sold out again. Just got another notification this morning and managed 3 rolls of the stuff. (y)
I think it won't work but I also think it's cool for people to try stuff to see what happens.
The spare tire bumper I recently printed was the exact same TPU material. I’m 99.999% confident that the layer bonds in the print aren’t even close to strong enough to withstand the tensile forces trying to pull them apart under articulation. As long as someone else wastes their time gambling on that .001% chance, I think it’s cool, too.
You should prove its a bad idea
Reactions: Apparition and sab
