I got mine used from a form member. Think I paid 1/2 price.
One of the best interior upgrades i have done.
Us Po folks got to compromise.
I bought some stuff from them about 12 years ago.. loved their logo.
I was blocked from their website a couple of years ago( I’m guessing they don’t deal with hobbits)
Danger , Will Robinson, DangerThat's okay , YouTube thinks I'm a Bot .![]()
Show-off!![]()
Will a jeep with a broken axle shaft and a lunchbox locker (Dana 30) in 4wd drive the one wheel? Does anyone know?
@Wildman
@Wildman
You da man.
Let me know when you get them out. Depending on when, I may take you up on it. We leave on New Years Day for the weekend to Windrock.I found them. I repurposed them as bumpstop extensions for my rear springs. I’m swapping springs and bump stops either this weekend or next, so if you can wait a week or two I’ll have one for you.
I know -he lives in the most beautiful place on earth
Every time he post a meal, I gain a couple of pounds
he gets to drive around in a killer Jeep
They’re sending stickers over there by the container load
And we’re over here, sucking on rocks.
It'd be 3 wheel drive if you have a rear locker...
Like this... View attachment 659009
Why'd I get drug into this?
Does it matter if it's a Dana 44? Same size u-joint....
Yes. The locker will still turn on both sides. Youll'd have to make sure the locker was engaged.What if the axle shaft is removed and there is only one side in there? Will it still drive that wheel
As long as it doesn't isn't a limited slip or open diff, the locker will still pull both sides. It won't know an axle shaft isn't there.What about a lunchbox locker
That's true in a limited slip or open diff. A locker doesn't care, it locks no matter the resistance or lack there of.Depends...
It's like unlocking one hub...Most will but I've seen some ratchet when not having that equal pressure from both shafts.
Didn't realize the lunchbox ones would ratchet. Good to know.I've seen some of the lunchbox lockers ratchet with a broken shaft or when removed.
