Merit is based upon what you perceive as the weakest most failure prone link.My current LJ tire/wheel setup, with 35's and beadlocks, weighs in at 107 pounds each. While I'm light on the skinny pedal, I can't help but worry that I'm pushing the limits for the small hub kit (YA WU-07).
FWIW, I have a small kit on the TJ, running a 31" tire, that has been wheeled in very tough conditions and proven to be ultra reliable. It however is much smaller and lighter, with no beadlocks.
Since a "next" purchase is a BBK, I need to make a decision about whether to stick with the small hub kit or go with the larger YA WU-08 kit. Am I overthinking this or is there merit to my concern?
U-joints are the same
Inner shafts can be the same, both 30 spline.
Bearings, seals, spindle nuts, spindles are the "same" for all intents and purposes.
That leaves the stub shafts and the locking hubs.
08 Hardcore hubs are far stronger.
08 stubs are stronger.
Question remains as to whether the 08 stub will fail before or after the u-joint. The 07 stub will typically fail at roughly the same time as the joint, but not always. Probably depends on steering angle.
