Summit seat foam review
Be shorter then?
They're way more comfortable, but they make me sit so high my console is now too low and my right shoulder starts to hurt on long (2+ hour) drives
thats what I said,mine is already too low.
Reactions: lBasket
Well hell, this makes me think twice about replacing the originals. I replaced the seat cushions in my classic car and they were taller than the originals and put me much closer to the steering wheel (no my belly did not grow larger). Definitely not as comfortable as before. . Gotta rethink my options now.
I'm thinking about putting something like this on it, I bet it would help
It probably isn't an issue with the later models since they have a shorter seat base
I put one of those on mine because the lid was cracked when I bought it. It’s ok, but I’ve noticed on long trips, my elbow feels raw and irritated for some reason. Not sure why, it’s relatively soft and smooth-ish, except for the tread design. Iv’e been thinking for a few years of getting one of the leather ones I’ve seen mentioned on this site but just haven’t done it yet.
Reactions: lBasket
If your foam is compressed you can rehydrate it and plump it back up using a steamer with or without the fabric still on. I’ve used the technique on boat, auto and wheeler foam for years.
  • Wow
Reactions: FarFire70
I believe mine has a bit, and I might have driven 2k last year.
Dang I think I have at least that much on mine, since I drove it to Moab and back since. If it doesn't flatten out soon I'm going to have to cut the base down and booger weld it back together.
Still worth it though since my back doesn't hurt after driving now, though
You need some weight behind you to make that happen. Maybe have Atlas sit on it for a bit....
I did mine. No need for hogs rings or pliers. Jeep used split rings. I just pulled the wires out of my upholstery, swapped the rings over to the new foam, and fed the wires through on the new seats.
It's a good time to consider seat heaters. You can install the panels and wire them up later. Metra or Dorman.
Reactions: John Cooper
