New Factor 55 Snatch Block Pro
Wildman
Over Analyzer Extraordinaire & Attention Whore
Staff Member
In the hills of WA
IT’S HERE
Introducing the ALL NEW FACTOR 55 SNATCH BLOCK PRO
Launch week deal: 20% OFF at checkout.
This is the new standard in snatch blocks. Machined in the USA from 6061-T6 aluminum and 304 stainless steel. Sealed grease-packed bearings keep your pulls smooth and consistent in sand, dirt, and mud.
Why it matters
A snatch block increases mechanical advantage or redirects your winch line. More power. More control. Less stress on your winch.
FULL VIDEO ON YOUTUBE
Key features
• Increases mechanical advantage or redirects winch line
• Precision machined in the USA from US-sourced 6061-T6 aluminum and 304 stainless steel
• Type III anodized finish for serious corrosion protection
• Swivel frame makes rope mounting fast and guarantees rope retention
• Works with steel or synthetic rope up to 7/16 in
• Radiused mounting hole accepts soft or hard shackles
• Sealed heavy duty bearings keep debris out and performance high
• Pro-level rigging guidance etched on both frames
• MBS: 51,000 lb
• WLL: 24,000 lb (2:1) / 12,000 lb (4:1)
• Weight: 3.2 lb
• CE and UKCA compliant
Compact. Strong. Ready for anything. Your winch has never pulled like this.
https://www.factor55.com/products/snatch-block-pro
Looks like they wanted to compete with the TRE snatch block. But, 3.2 lbs is quite a bit heavier than 2 lbs.
I think my obsession with vehicle weight isn't a secret...
Edited to ad: The pound saved in this case is a two-fer: 1) Vehicle weight, and 2) Projectile weight, if the shackle securing the snatch block fails.
In addition to the extra weight, F55 missed several small aspects of the elegant shape and form from the alleged source material while piling on their own cluttered brand identity.
Hopefully this leads to more competition in the lighter snatch block market. As far as I am aware it's TRE, F55, and those little "slip" rings - though I haven't looked in a good while since my old TRE is still on the top of the pile and I hate spending money on the same thing twice.
Reactions: Wildman and Zorba
I have used my ring twice so far and it has been adequate
I've got one of the "new" TRE snatch blocks so I'm not looking to buy another one either but this had popped up in my FB feed and thought it was worth posting about.
Since rope has become more the standard over cable you would hope/think more vendors would follow suit to make more light weight snatch blocks.
I have two different sized rings also for those times I'm doing a multi angle recovery.
Reactions: lBasket and rasband
