Wildman
Over Analyzer Extraordinaire & Attention Whore
Staff Member
Introducing the ALL NEW FACTOR 55 SNATCH BLOCK PRO
Launch week deal: 20% OFF at checkout.
This is the new standard in snatch blocks. Machined in the USA from 6061-T6 aluminum and 304 stainless steel. Sealed grease-packed bearings keep your pulls smooth and consistent in sand, dirt, and mud.
Why it matters
A snatch block increases mechanical advantage or redirects your winch line. More power. More control. Less stress on your winch.
Key features
• Increases mechanical advantage or redirects winch line
• Precision machined in the USA from US-sourced 6061-T6 aluminum and 304 stainless steel
• Type III anodized finish for serious corrosion protection
• Swivel frame makes rope mounting fast and guarantees rope retention
• Works with steel or synthetic rope up to 7/16 in
• Radiused mounting hole accepts soft or hard shackles
• Sealed heavy duty bearings keep debris out and performance high
• Pro-level rigging guidance etched on both frames
• MBS: 51,000 lb
• WLL: 24,000 lb (2:1) / 12,000 lb (4:1)
• Weight: 3.2 lb
• CE and UKCA compliant
Compact. Strong. Ready for anything. Your winch has never pulled like this.
https://www.factor55.com/products/snatch-block-pro
