This is a very specific chart for guys wanting crawl ratios.
Horribly deep gearing for a daily driver.
The only thing accurate about the ratio recommendations is for guys running 35s or bigger or guys running the 4 angry squirrels. The smaller the engine or bigger the tire, the less room there is for compromise.
For the average guy 4.0L running 33s and the 32RE 3 speed automatic with no overdrive, 3.07s are perfect. 2200rpm at 70mph will return reasonable gas mileage and dropping to 2nd gear will give 3300rpm at 70mph, perfect for hills, headwinds and passing.
The only reason to go deeper is lift off the line. Far more important than power band at 70mph is getting started from a stop. With 3.07s off road, or on a forestry road, the range of speed in 4LO, in each gear makes for relaxed driving.... and the ability to do 60mph in 4LO. I'd go into 4LO as soon as I left the pavement with 3.07s. 90% of my wheelin' is mountain trails, forestry roads, old logging roads with the odd foray thru a ditch to reach a beach. I have zero need for ceawl ratios but I do want reasonable mpg.
Gear for the wheeling you do.
