Shocks are re-assembled. Painted them over the last couple days. I
should have hit them with some Epoxy clear...I didn't realize how much the shock oil would soften the paint I used. Its not the end of the world, but I definitely felt the paint get a little tacky everywhere the oil went (and its impossible to fill and bleed them without making a mess). I supposed I could hit them with clear now...since I'll probably need to pull them apart again to change shims.
Also had to spend a little more money. I really didn't like how much corrosion there was on one of the post mounts (like for the front upper mount), so I did some DEEP internet research and found out they are replaceable. Not super easy to find, but they are available (241-02-050 and 072, if you're so inclined). Takes a bit of heat to get them out, since they poured about a cup of red locktite into the threaded pocket in the shock body too. Anyway...The offending posts.
The one on the left was the one I was really worried about. These are 2-5/8" long. I replaced them with 3" long ones, since the shorter ones were pretty hard to find. Anywhere I did find them, they only had one in stock. They were 17 bucks, each...but I can't make em for that. So, add another 34 dollars to my spreadsheet.
Here are the shocks, fully assembled and ready for a nitrogen charge.
and a close up of the Schrader valve mod I did. I really don't know why they put that dumb pellet system in these, other than to dissuade the "general public" from hooking up a gas station air line to their shocks and letting all the nitrogen out.
Pretty happy with how these turned out. For what I have into them, it was definitely worth the time. I would have spent 200, min, on new shocks anyway, and had garbage. These are decent. They are not as good as factory race series, but they are still pretty well built. The ONE thing I think I'd do differently is put the factory race IFP in. The stock ones are plastic and use an O-ring seal. They have about 1-1/2 threads of a 10-24 screw in the center of them (which is how you're supposed to pull them out of the reservoirs and set their starting position). I stripped every one. The O-ring has quite a bit of stick-sion (resistance to start moving). The Factory Race IFPs are aluminum and use the brown turcite bands to seal. They also have a 1/4-28 thread in them of proper depth to actually thread a screw in and pull them out/set their position. They move much more easily, with resistance to start. Overall, just a much better design. The bores on the performance series vs the Factory race are the same, so the parts would interchange easily...just at a cost.
Next up...Install. Deer hunting season is upon us though, so I'm not exactly sure when I'll get around to that. I did find these from Iron Rock Offroad, to help with the Bar pin vs shock eye up front (and the rear Bar pin from the JK shocks is too wide for the TJ, I believe). This will help save some time when it comes to mounting (as long as the lengths work out).
https://www.ironrockoffroad.com/product/bar-pin-eliminator-pro-xjtj-rear.html
https://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=16085
