That video is very instructional, and better than the one I saw years back! Without benefit of see-through shock body and reservoir, I was only guessing by dyno results that I'd encountered cavitation. I could clearly see a dramatic drop in damping force above a certain velocity, and I concluded it must be cavitation. I remember immediately disassembling the shock, thinking I'd see air in it, but the fluid was crystal-clear. That's about when the Ohlins rep "schooled" me on what cavitation is and later showed me a video.Non VHS version shows very clearly what I think you may have been dealing with on the bike shocks. They consider cavitation to be the phase change from liquid to gas. This video shows the cavitation start, then fill the shock body with the cavitation, then as the cycling continues, the cavitation migrates through the reservoir connection, then through the valving in the reservoir, and then finally into the reservoir. Start at .29 and watch it several times, pretty clear to see what is going on.
