Zone 4” Lift Install Help
So ran into another snag. Will get some pics later. The JKS rear bar is hitting the gas tank cover. So not sure what I am going to do there. Was I wrong in thinking I could adjust the upper rear arms and set the pinion angle up without an SYE? All the track bar brackets say you must have an SYE it seems, or different shaft.
SYE will affect the vibes and allow you to point the pinion in an acceptable manner.
You might be able to take an 1/8" or a 1/4" out of all four arms exactly and bring the rear axle forward for clearance.
But my guess is once you road test things you're not going to like life without a SYE and double carden driveshaft.
Thanks Mac. The problem is though I am only using adjustable uppers, the lowers are from the kit and they are fixed. Should I set the uppers back to stock maybe?
Bad thing is I have a SYE kit already, but didn’t want to install it yet since I am going to pull everything out for the engine swap.
No bracket. I did not install the one with the kit either. I could install the lift kit bracket but figured it was not needed since using the adjustable bar.
I've had and/or installed more than 10 of those lifts. The one with the kit isn't angled either. I needed the angled bracket to stop the CLUNK of my rear track bar hitting my gas tank skid every time I took off too fast. $25 well spent.
Reactions: NashvilleTJ
So you can run the angled one even without the SYE? Why in the JKS instructions do they say do not use their bracket unless you have the non-stock shaft? if it’s fine to use one I will get one. Thanks
I can't help you with the instructions of what to do. I've never read instructions unless @mrblaine puts them in the products he sells. I trust his expertise 100% of the time. All others give you instructions that are written by people who've never installed anything IMO.
You’re trying to set things up for clearances. Once you rotate the rear pinion up to point at your output shaft for an SYE the rear trackbar tends to hit the gas tank or gas tank crossmember, so you can use an angled trackbar bracket at the axle end to move the trackbar forward so it doesn’t hit. If you’re planning an SYE you should go ahead and do it IMO.
Hello,
I am installing a Zone 4” lift on my TJ and have some questions. Now, just to preface all of this, I have a 2.5 that will much later get an LS swap. So I do not want to spend any extra money on the Dana 35. I have an 8.8 and Artec kit waiting to be welded up one day. Not in the near future though so plan on seeing how long this 4 cylinder will last. I also already did the Savvy 1” body lift to be ready for the LS.
Anyways, in the rear they say you need to drill out the bracket for the upper control arms to put in caster/camber bolts. Can I skip this step since I am using Core adjustable uppers and just use stock fasteners? Any recommendation on a good baseline setting?
I also bought a JKS adjustable rear Trac bar. Any numbers good for a baseline on that? Should I use the drop bracket that came with the Zone kit with the JKS?
For now I plan on using the T case drop they send if that matters. I plan on doing the SYE after I get the 8.8 in, so holding off on all that since I will need different lengths most likely on the driveshaft.
Also this will mainly be a street Jeep, so not looking to spend a ton in suspension and get that last bit of flex. Most flexing it would probably see is a pebble in the road. I plan on running JL Rubicon wheels with 34’s. Yes I know it will run like a pig and I can always go back to the 32’s if it’s that bad.
Thanks!
I was just about to answer all your questions, but then I saw your plan to swap in an LS. So, you're on your own...
Got ya. Thanks @TheBoogieman. Doing all this research online gives so much conflicting answers. People sound like your Jeep is going to explode if you do not dump a ton of money on a lift. I had a 2006 that I put a cheap Rough Country 4” lift on about 13ish years ago and to me it rode great. Drove it to FL from NC and back without issue.
Reactions: John Cooper
I would install it, but the problem is I do not want to buy 2 driveshafts since the 8.8 will be going in. This was just a fun start up because the suspension was completely shot on my Jeep. 😄
Also @TheBoogieman is there a good budget bracket you like?
Install the JKS bracket.
What’s wrong with an LS swap? Especially in a 4 banger? If it was a 4.0 I would leave it, but this 2.5 is on its last legs.
Hemi, hemi, hemi his name is Jimmy. Really Jeff was just jerking your chain.
JKS. You should be able to go ahead and install it before the SYE.
Nothing at all, actually. Just some good-natured ribbing. The Hemi guys and the LS guys here have a good time poking each other.
That said, the best thing about dropping in an LS is you don't have to worry about upgrading your Dana 35...
See how this works?
lol Thanks @John Cooper
I looked into that swap as well, BUT for me I already have an LS swapped Mustang, so it just makes sense for me to stay in that realm. I already have the extra parts, programmer, etc 😄
Okay ordering the bracket now. 😁
Reactions: ColoJeep and Rickyd
All kidding aside, an LS in a mustang is just sacrilege!!!!!!
Man you so could have dropped in a 427 stroker.......... a Coyote......
Please at least tell me you didn't do this dis-service to a Fox Body.........
:ROFLMAO: :ROFLMAO: :ROFLMAO:
