Ford 10R80 transmission woes
Chris
Administrator
Staff Member
Gillette, WY
I love my 2019 F150 3.5 Ecoboost. It's fast, it's quiet, it tows everything I need it to, and it's very comfortable to drive, riding more like a car than a truck. However, this love affair is starting to end.
At 60k miles I figured it was time for a fluid and filter change. I went to a highly reputable local transmission shop (ATS) to have the transmission fluid changed and they had it done in a day. The cost was $800 but from what I'm told, that's an average price to service one of the 10R80 transmissions on one of these things.
I spend the next few days driving it and I notice it shifts smoother. Everything seems fine and I'm a happy customer.
About a week after getting it back I'm driving home from the rec center and all of a sudden I notice it starts losing power intermittently and the gear indicator shows it hunting for gears at an erratic pace. The gear wrench icon comes on the display. Fortunately I'm not too far from home so I make it back. I get out my FORscan app and connect to the OBDII port. It's giving me a TCM code, P07F7, "Gear 10 incorrect ratio".
I notice when I turn it off and start it back up the gear icon is gone and it drives fine for 30 minutes or so before it starts doing the same thing again, hunting for gears.
First thing I do is call the transmission shop and ask him if there is anything that could have been disturbed while he was in there. He tells me definitely not, but that the 10R80 has some TSBs from Ford where they reprogram the TCM to adjust shifting. I told him I thought it was a bit odd that this problem didn't exist until I had the fluid changed.
ChatGPT gave me the following explanation:
ChatGPT said:​
Excellent (and important) question — and you’re not alone. Many F-150 owners report that their 10-speed (10R80) transmissions began slipping, hunting gears, or throwing codes like P07F7 only after a fluid and filter service.
Here’s why that happens, broken down clearly:
🧩 1.​
Ford’s 10R80 is extremely sensitive to fluid characteristics — the friction modifiers, viscosity, and thermal behavior all affect how the clutches grab and release.
  • When you replace old, worn fluid (which had degraded additives and a higher friction coefficient) with fresh, low-mileage Mercon ULV, the new fluid can cause clutch apply timing to shift slightly.
  • This means the TCM’s learned adaptive tables — which had adjusted over tens of thousands of miles to the oldfluid’s feel — are suddenly “wrong.”
  • Result: harsh shifts, flare-ups, hunting, or “incorrect gear ratio” codes (like P07F7 for 10th gear).
  • That’s why Ford’s own TSBs explicitly say:
    “After fluid or component replacement, perform TCM adaptive learning reset and relearn drive cycle.”
If this wasn’t done, the truck is essentially trying to use old shift pressures for a new friction environment.
⚙️ 2.​
The 10R80 uses a fine screen internal filter. When replaced, the new filter allows freer fluid flow — which changes pump output pressure characteristics slightly.
The transmission control system uses solenoid current to regulate pressure based on expected flow resistance.
If that flow changes suddenly, clutch apply timing can be off by milliseconds — enough for the PCM to detect “incorrect gear ratio.”
🧰 3.​
This is the most common culprit after a service.
The 10R80’s fill procedure is very specific:
  • Truck must be running, in Park, level ground.
  • Fluid temperature must be between 185–200 °F (85–93 °C).
  • Level is checked with the overflow standpipe plug on the bottom of the pan — not a dipstick.
Even being ½ quart low or overfilled can cause:
  • Slipping or shudder in higher gears (especially 9th–10th)
  • Delayed or hunting shifts
  • TCM codes like P07F6 / P07F7
If your shop filled it cold, or didn’t follow the exact “engine running, warm, check plug dribble” method, the level could be wrong.
🧲 4.​
If your transmission had clutch material or varnish buildup, a fluid change can loosen debris that then clogs a valve or solenoid screen.
  • The valve body in the 10R80 has tiny hydraulic control passages.
  • Debris here can stick a valve partially open, causing the PCM to see a mismatch in expected vs. actual gear ratio.
This explains why sometimes the problem shows up immediately after a fluid service — a valve may have been working fine until fluid flow stirred up contamination.
🧠 5.​
Even if the fluid and level were perfect, the adaptive tables still hold old “clutch fill times” and pressure maps.
So the PCM might be commanding slightly too short or too long clutch fill times for the new fluid — which leads to ratio errors.
That’s where the TCM Adaptive Learning Reset you’re planning comes in — it’s literally designed to fix this exact scenario.
I performed the TCM adaptive table reset about an hour ago using FORscan. So far it hasn't acted up since, but I've also been driving it like a grandma since I did that since it specifically states to avoid hard driving for the first 100 miles.
The internet is afoot with horror stories of the 10R80 transmission and all the failures. The stories of people having to have them replaced at 50k miles (and sometimes less) are all over. Ford did what they did with virtually every other vehicle they've ever made, built a crappy transmission.
This thread is more-or-less a rant. I'm just beyond sick and tired of not being able to buy anything that is built to last. All of it is built with planned obsolescence in mind. It's all built to fail because they want you to keep coming back. Finding anything quality these days seems damn near impossible and it's ubiquitous. It isn't just cars, it's appliances, electronics, etc.
I don't think there is any vehicle made after probably 2005 that isn't littered with problems.
What grinds my gears even more is the fact that they don't build things simple anymore. The transmission has to be electronically controlled, it has to "adapt" to the way you drive, and in order to do so requires layers of complication.
This isn't like the old 700R4 in my 1973 Chevy K10. I can't just go out to my garage and work on it myself. You need some sort of advanced training to work on these new vehicles and it sucks the life and fun out of owning them. All of this they would say is a trade for more "efficiency" or "better driving manners". I don't care! Like @Zorba, I'd rather they sell me some basic truck with an old school engine and transmission so that when it does break I can fix it myself.
Anyways rant over. I sure as hell hope that this TCM adaptive learning table reset fixes the problem because a new transmission is in the ballpark of 8-10k. If I end up needing a new transmission I'm just going to dump the truck. I'm not paying that much money for a new transmission that might not even last any longer than the last one. Why would I? In fact, I'd be a fool to pay that much money for a piss poor designed transmission.
Sell it and daily the k10
If it ends up needing a new transmission, that’s the plan. I’m going to buy a winter beater to drive in the winter so the K10 doesn’t have to get rusty or anything. Then I’ll just drive the K10 during the nice seasons.
This is the last time I’ll ever buy a newer vehicle. After this it’s 2005 and older for me.
Well that's not fair, they made the GMT800 until 2007 😉
Just make sure you don’t get one with the crappy 4L60E. Get a 2500 with the 4L80E.
The GMT800 though was high on my list of replacement vehicles until I went down the rabbit hole of all the issues with the 4L60E. If I could find a Suburban 2500 I would probably go that route.
Reactions: StG58 and lBasket
The 10R80 is definitely a finicky beast, none of the transmission shops i deal with daily have anything nice to say about it
Electronic transmissions scare the hell out of me, watching the gear position indicator jump around in our 2020 JLU makes my eye twitch
Reactions: Zorba and Chris
I recently bought a 94 Chevy k2500 . It's the last year without an airbag and has the simple TBI and the 4l80E . Like the TJ , the computer is limited to basically running the engine and shifting the transmission . If you have to replace several parts to find the culprit , it's not going to break the Bank and it's fairly easy to work on . It's comfortable to drive around and can tow everything I need it too .
Love it! That’s what I’d like right there for my daily. Something I can still work on myself.
Every time I watch that gear indicator hunting it scares me. Electronic transmissions are just another way to fix a problem that never existed in the first place. It’s just another thing that adds complexity, and when it breaks it will cost a fortune to fix. Not to mention the average DIY mechanic can’t fix it in the garage.
I've heard a lot of guys keep them in sport mode or tow/haul for better performance and less gear hunting, is that an option on yours? I've never had one but soon I will have a new 10R60.
Yeah but who wants a 1/4 ton anyways!
That is an option on mine. The truck is much more fun to drive in sport mode. That’s actually a good idea that I never thought of. It definitely does a lot less gear hunting when you put it in sport mode. When it’s in the normal mode, you can see it hunting for gears nonstop, and it gets quite annoying.
Reactions: John Cooper
You're starting to sound like me. Next thing we know, you'll don a skirt and join a Belly Dance class!
Watching this quite long video 4 months ago on the jointly designed Ford-GM 10-speed trans made me even more pleased my 2014 F150 FX4 is equipped with the "old school" Raptor-spec 6.2L V8 and 6-speed auto:
Former GM Powertrain Engineer REVEALS Truth on Quality Issues - Full Interview
My truck only has 24k total miles since factory ordered new, so it'll long outlast me...
My brother had a Ford F150 with that transmission. It started going out on him at 90k miles if I recall.
Ford doesn't build good automatic transmissions. Neither does GM or anyone else for that matter though.
As @John Cooper stated, that ended with the TH350, 400, etc.
So I guess it could be painful to bring up a CH - 465 truck 4 spd. is reliable to around 350,000 miles . Yes , it shifts like the truck transmission that it is , but it's totally reliable. Automatics are fine for playing in big rocks only or used in a taxi cab , otherwise I'm not a fan.
You can thank the EPA for all these gee-whiz transmissions, automatic stop/start, cylinder deactivation, and the other electric bugaloos that eke out an additional 0.25 MPG on the EPA loop.
Most people trade out in less than 5 years so the manufacturers don't really care about things lasting past the warranty.
Cars are becoming more like appliances: Don't fix them, replace them.
Edit: I almost forgot my favorite part of all the EPA regulations that has been implemented into the automobiles: Lifetime Fluids.
Transmissions are now often filled with fluid that is rated for the lifetime of the unit, because if Carl decides to change the transmission fluid on his own he is obviously going to pour the old fluid into the nearest trout stream. He'll probably throw an old car battery in there too.
The 10R80 is rated for 150k on the transmission fluid but most say change it at 25-30k with a new filter every other change if you want it to last.
I hope I'm not being premature in saying this, but it's been three full days since I used FORscan to reset the adaptive learning tables in the TCM module.
After doing so the transmission is shifting fine again these past three days. I had to reset the tables and then do some very specific driving and apparently the TCM was able to adapt to the new transmission fluid and re-learn how I drive.
This is next level retarded. The transmission is so sensitive to fluid that adding new fluid in place of the worn older fluid causes the pump in the transmission to act up.
This is one of those things has no reason whatsoever to exist on a vehicle. All it does is add more layers of complexity so the average DIY mechanic can't work on things anymore. I suspect it's all there due to governmental regulations. Everything the government touches it makes worse. Not surprising at all when the people in government are the most unimpressive, unqualified people imaginable.
In any case, I'm hoping and praying it continues to drive well.
I'm also glad I was able to find out about this whole TCM re-learning procedure. Now I know I've got to do this every time I change the fluid. Again, absolutely unnecessary and uncalled for.
