Gears and lockers
Assuming 5 speed's....
4:10 is obviously agreed not enough gear for 33's
4.56/4.88 is almost negligible at crawl or 1st gear at stop light
4.88 suffers with MPG above 60MPH as previously stated. MPG is not what I am after, but is a good gauge of losing efficiency at 70 MPH. More energy to do the same work.
4.88 makes sense if you have future plans?
The problem is the same as always, we aren't discussing 33's, we are discussing 31.5's.
If you're going for crawl ratio you'd change your transfer case, no?
If you have plans for 35s you probably don't want 4.88s.
My mpg going from 3.55 to 5.13 didn't change noticeably.
"33s" on 5.13 with ax15
Also since people mentioned this, I don't find 1st gear useless either. Sorry I don't know my actual rolling radius either
Wait Mickey Thompson lists the actual OD of the tire as 32.7"
Give me a known highway speed in top gear, which transmission and the exact engine RPM assuming the speedo is accurate and I can get you the exact rolling radius.
Mickey Thompson does, and all the other manufacturers do, but that number is always completely worthless. Tires are always about an inch smaller than that number. 31.5-31.7 is typical for "33's."
Ah ok I went to look for that rev/mile figure and they just had that, thought it might have been an actual measurement.
I checked and I don't have any pics of that unfortunately. 70 is just about 3100 rpm I believe in 5th from memory
The number isn't worthless, it just isn't very useful for gearing discussions. If the tires were made from steel like trains use, then we wouldn't struggle so much to get folks to understand that the loaded tire radius is what matters, not the horizontal diameter.
When you get something other than "just about", I'll be glad to get you an answer that is other than "just about".
Reactions: lBasket
Right, but the tire doesn't get smaller when you put load on it, it just flattens out and elongates the tread. You still have to travel around the full circle. I don't think that circle is ever the advertised size.
Take a simple Goodyear tire for example: 33X12.50R15 Duratrac
Advertised Diameter: 32.5"
Rev/mile figure: 643
643 comes out to 31.37"
Why would the manufacturer's own two numbers contradict themselves? To me, the rev figure is the only one that is ever accurate. The manufacturer doesn't know how much the tire is going to deform under different vehicle loads and yet for me the distance it takes that tire to travel a mile is always accurate and never changes.
Reactions: Rickyd
Right, but the tire doesn't get smaller when you put load on it, it just flattens out the tread and elongates. You still have to make it around the full circle.
Don't know, don't care. I know how to do it in the gear calculator and that's all I need. And, the result on the vehicle is what matters which is very easy to do in the calculator.
I do too but I'm just explaining why I have always believed and still believe the advertised diameter is worthless and always will be.
The inner splines at the carrier have convinced us many times over that 27 spline will bite you in the ass when you least need it to. Even if you couldn't predict whether a 27 spline set up would break at the inner or the outer, you still want nothing to do with them breaking at the inner.
100% TRUTH!
You need a point of reference when you buy a tire other than depending on cumulative experience reported by wonky Jeep owners.
And that's exactly my point - the manufacturer gives me two points of reference and they contradict each other so I only use one of them.
Here, try this. I have 33 1/2" of width I can lay a tire down into, length isn't a problem. How many revolutions per mile will fit in that spot?
Don't know, don't care. I drive them, I don't lay them down in confined spaces.
More seriously, my point always has been and still is, that the tire itself is actually smaller than the advertised diameter number from the manufacturer. So even if I'm looking at a tire that claims to be 33.5" (and if that's what my space constraint is), it's probably 32.5" anyways and so what fits between the walls will still be more than what was advertised. So in this case all that number will guarantee is that I end up with a tire smaller than the space I have so long as the advertised number is 33.5" or less.
You ever wonder how folks make it onto my list of folks I ignore?
