A adventureboss TJ Enthusiast Original poster Joined Aug 1, 2023 Messages 249 Location Phoenix, Arizona Sep 21, 2025 #1 I was checking for play on all my u joints today. Where the hell are my wheel axle u joints? I’m so confused. There’s a rubber boot instead? Did the previous owner put in an aftermarket shaft or something? Reactions: L J
M machoheadgames LED turn signal club Supporting Member Joined Jan 21, 2021 Messages 2,637 Location Dallas, TX Sep 21, 2025 #2 Previous owner installed a CV axle shaft instead. Reactions: GATORB8
CharlesHS TJ Guru Supporting Member Lifetime Supporting Member Joined Mar 10, 2020 Messages 6,384 Location Jacksonville FL, Quezon Philippines Sep 22, 2025 #3 There appears to be a crack in the CV joint boot (2nd rib going left to right) which may be where the oily dampness is coming from. Reactions: TheBoogieman
Ctdriver86 TJ Enthusiast Joined Apr 22, 2024 Messages 113 Location Oklahoma Sep 22, 2025 #4 Grand Cherokee front end swap?
CharlesHS TJ Guru Supporting Member Lifetime Supporting Member Joined Mar 10, 2020 Messages 6,384 Location Jacksonville FL, Quezon Philippines Sep 22, 2025 #5 Ctdriver86 said: Grand Cherokee front end swap? Click to expand... If so…, must be from a ‘99-04 WJ; they had CV joints. Reactions: Ctdriver86
