Welp I'm always learning
, every day! (My ego is pretty bomb proof) Reading through all this it definitely makes sense. My misunderstanding was thinking that if you push 1-1/2 oz vs 1 oz of fluid into a smaller area (just for example) it would increase the pressure but I see that is incorrect.
I tried to edit my earlier post to correct it but it's not allowing me that option now.
Bottom line is I'll plan on going back to the OEM size. I'll be sure to come back and report the difference.
I guess the 1" larger rotor and small change in piston size was enough to get me past the brake fade and give me enough stopping power to convince me it was a legit upgrade... OR maybe replacing all the fluid made the real change... either way... Lessons learned!
I'm more interested in learning how to be a better Jeeper than fluffing up my ego
Thanks again!
