Rear to front seatbelts swap?
CarlosRangel
Mexico
Hey, fellas. Quick and potentially dumb question: can I swap the rear seatbelts of my 98 TJ to the front? The front ones work but do not retract as they used to and i hate when they get caught by the door. I never have people in the backseat anyways...
I was messing with this just yesterday the base is bigger I don’t know if it would fit without cutting the plastic on the reel up. Mine was locking up when I would try to put it on like it was on an incline all the time. I pulled mine off and blew it out real good with the compressor and it’s working real nice now.
They're significantly different shapes. Literally was just pulling a set from a 2000 to sell. But if you made some extension tabs you might get them to work.
I bought a new set from Seatbelt Planet for my 97 and they're better than the 25 year old originals but not by much. They really suck.
The salvage yards have the front belt for $20 each side. Just take a close look at them to make sure they are in good shape. I only needed to replace the driviers side belt.
Reactions: macleanflood
Thanks! Will try that!
The thing about anything in a salvage yard is that it very likely was wrecked, which may have compromised the seatbelts. You’re supposed to replace seatbelts after a wreck, and you can be certain those haven’t been replaced. IJS.
Many years ago one of my fronts wasn’t retracting so I took it apart and wound the spring a couple more turns, then put it back together. If you’re handy with mechanical stuff it’s relatively easy, but you have to be careful handling the spring. It’s a flat metal band that can cut you, and the coiled up spring likes to unwind itself.
If the jeep is a daily driver, you might want to purchase new seatbelts. I replaced all the seatbelts in my daughter's jeep because seatbelts expire after about 15 years.
Reactions: hear
