I have a 2004 Jeep TJ. I am getting really bad fuel fumes smell in the cabin while driving for awhile. Did a smoke test a no smoke could be seen. Fuel system holding pressure after turning off the smoke machine. Open fuel cap and the pressure releases or Pull of the smoke hose at the purge control valve while under pressure and pressure releases. Has anyone had an issue with the canaster getting so saturated that it cant absorb anymore vapor. I was bad many times when refueling and not stop filling after the first click. No MIL on but I am in Phoenix AZ and don't believe the systems does the leak test when its as hot as it is here.
I do not think its a fuel leak as I see no signs of any and engine fires up instantly on startup hot or cold. I've had issues with hard start before due to a bad fuel pump check valve so I am sure the fuel system is not leaking.
