Fuel System Pressure Release
Rut Row
FOG
Keedysville, MD
I got tired of searching so hear goes. I'm going to drop the tank on my '03.
1) The SM says "This vehicle is equipped with an ORVR (On-Board Refueling Vapor Recovery) system. Because of this, the fuel tank may be drained the conventional way through the filler cap opening." Is this true? Obviously I haven't tried it yet.
2) The SM gives the following on how to release the pressure in the fuel rail. I'm wondering if the steps 6-12 is really necessary.
Use following procedure if the fuel injector rail is, or is not equipped with a fuel pressure test port.
(1) Remove fuel fill cap.
(2) Remove fuel pump relay from Power Distribution Center (PDC). For location of relay, refer to label on underside of PDC cover.
(3) Start and run engine until it stalls.
(4) Attempt restarting engine until it will no longer run.
(5) Turn ignition key to OFF position.
CAUTION: Steps 1, 2, 3 and 4 must be performed to relieve high pressure fuel from within fuel rail. Do not attempt to use following steps to relieve this pressure as excessive fuel will be forced into a cylinder chamber.
(6) Unplug connector from any fuel injector.
(7) Attach one end of a jumper wire with alligator clips (18 gauge or smaller) to either injector terminal.
(8) Connect other end of jumper wire to positive side of battery.
(9) Connect one end of a second jumper wire to remaining injector terminal.
CAUTION: Powering an injector for more than a few seconds will permanently damage the injector.
(10) Momentarily touch other end of jumper wire to negative terminal of battery for no more than a few seconds.
(11) Place a rag or towel below fuel line quick-connect fitting at fuel rail.
(12) Disconnect quick-connect fitting at fuel rail.
Refer to Quick-Connect Fittings.
(13) Return fuel pump relay to PDC.
(14) One or more Diagnostic Trouble Codes (DTC’s) may have been stored in PCM memory due to fuel pump relay removal. The DRBt scan tool must be used to erase a DTC.
Pull the fuel pump relay and run the engine till it dies. Good enough.
Since you're in there I'd install a Racetronix 1/8" adapter...
https://www.racetronix.biz/p/adapter-qdf-5-16qdm-5-16-1-8-port/qda-56f56mp
And then either a fuel pressure gauge or Schrader valve on your fuel rail.
The Schrader valve would let you test pressure and release pressure the old school way.
If you haven't installed a DEI heat wrap kit on your rail or refreshed the o-rings...now might be the time.
-Mac
Reactions: ColoJeep
-Mac
where does said adapter go? If it is easy, I'll do it. I'll hold off on the heat wrap as I'm about to start installing MORE MML, UCF extra clearance skid, new drive shafts, and cutting the gas tank skid 1". That is plenty of opportunity for something to go wrong 🤣
