Pretty much. I did scale my 0.5ms factor, but your change is so small that I wouldn't think it would matter.
Be sure to scale the startup tables as well (if you haven't already) since the injectors are putting more fuel in than needed. Not a big deal (especially with your small adjustment) but sending unburnt fuel to the cats, especially if they're already hot, can shorten their lifespan.
In regards to timing, I also added a few degrees of advance to the cranking spark tables for a faster start. (I do have a faster aftermarket starter as well so my cranking RPM is higher than normal.)
My tune is based on a
@Flyin' Ryan Performance canned tune so unfortunately I can't share my main spark tables. However I will say his tune is a very good starting point if you are willing to pay. There are a few additional changes I made since his tune though.
